adding a 3 remote to 7000 series
acer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acer Quote  Post ReplyReply Direct Link To This Post Topic: adding a 3 remote to 7000 series
    Posted: 03 Mar 2017 at 8:45am
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2017 at 8:46am
Are you asking or telling?
Wink
I am a Russian Bot
acer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acer Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2017 at 8:49am
wow i hit the button too soon i guess, has anyone ever added a 3rd remote on a 7060? is it any more involved than adding the lever in the console plus the cable and adding a valve to the stack with hoses and linkage of coarse,or is it a PITA?
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2017 at 9:36am
I just added a 3rd remote to our 8050. The worst part for me was installing the lever. First off the pin was froze, then dangling out the cab and working around the seat trying to line up all three levers and spacers was aggravating. I was told to replace all o-rings between valves, which I did. The 3pt valve has a small poppet spring inside. Also, lower your lift arms before loosening valve bolts. Had I remembered that, it wouldn't have made such a mess.
Leon B Mo
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2017 at 10:06am
I added a 3rd and 4th in both the 7045 and 7080. I was told that I needed to cut off most of the threads of the cable end inside the cab as because it is just a little to long for the yoke and lever.
Install everything and check to see if I am right BEFORE you make a cut. I has been about 10 years since I have on one.
To add a 4th, take a long lever from the front set and make 2-90 degree bends in it. The lower bend brings the lever just under the front cables and the second bend runs the lever upward just behind the third lever. You also have to add a cable holder in the back of the console for the forth cable.
nickia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2017 at 10:10am
any one have a photo of the levers in the cab after a 3rd or 4th lever was added?
acer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acer Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2017 at 12:31pm
thanks for the info,never thought about a 4th one but while im at it i may consider that
acer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acer Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2017 at 9:49am
i have just about rounded up everything i think im going to need for this project except for the tie bolts or thru bolts whatever they are called, are these a hard grade or something? agco is very proud of em @ $28.00 each and im not willing to pay that just yet
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2017 at 12:09pm
I'm sure they are probably pretty good stuff, even tho they are only torqued to 12-15 ft lbs. I'd see if Cat doesn't have a regular Gr8 bolt pretty close to correct length and put the heads to the left(nuts to the right) and use Cat flat washers under the heads to shim the length to where you want it.
