Bad PTO Clutch Cable?
Tractorpunk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tractorpunk Quote  Post ReplyReply Direct Link To This Post Topic: Bad PTO Clutch Cable?
    Posted: 02 Mar 2017 at 6:57am
My 6140 will be mowing again this year, and last year I noticed how the PTO clutch lever was grinding as I engaged it with any implement attached.
The disconnect lever above the PTO engage lever pulls back but does not help at all.
Time for a new cable? The cable looks intact and has no play in it.
Something else I should be doing? Thanks for any advice!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tractorpunk Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2017 at 7:54am
FWIW, the linkage was frozen into the transmission and not moving at all. I sprayed lubricant and got it to move a bit with with the PTO clutch handle, but engaging the PTO still results in the PTO grinding as it engages. Ideas?
lowell66dart View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 03 Mar 2017 at 11:36am
What happens if you shut the tractor down then engage the PTO?
AC 6080 (8030,7060,200,175,D-17HC, 6040,160,6140 all gone) Farmall 1066 & 656 Hi-Clear (for sale), White 2-62 High Clearance, JD 4255 Hi Clear.
This page was generated in 0.071 seconds.
