D17 diesel
Fenceguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fenceguy Quote  Post ReplyReply Direct Link To This Post Topic: D17 diesel
    Posted: 28 Feb 2017 at 2:38pm
I just bought a d17 diesel sn# 170 2754. It has square fenders and the hydraulic pump is externally mounted on right side of tractor. The starter is a 1113082. I need to find a starter and a lot of other parts of someone could help me figure out what year this thing is. Thanks
Edited by Fenceguy - 28 Feb 2017 at 2:38pm
Macon Rounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2017 at 3:20pm
Please post a photo and we can help you out.
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2017 at 3:28pm
Serial number is on the left side of the bellhousing sitting in the seat. Someone will be able to tell you the year.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fenceguy Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2017 at 3:33pm
That is the serial# I posted. 170 2754
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fenceguy Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2017 at 3:45pm
https://goo.gl/photos/qeu7DYMc42yRd8Ku5
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2017 at 3:47pm
Sure enough, I don't know how I missed it. Serial number matches a 1968 one seventy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2017 at 3:53pm
What you have is parts of 2 or more tractors. From your photos, the front radiator shroud is from a series I or II tractor. Most likely the engine is too. And the torque tube is from a 170 and most likely the rear end is 170 also.
Edited by Macon Rounds - 28 Feb 2017 at 4:00pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fenceguy Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2017 at 3:54pm
I thought all 170 motors were Perkins?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fenceguy Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2017 at 3:57pm
So I gs I'm gonna have a nightmare to buy parts for!! I need a starter right now, but not sure if the 1113182 Delco starter is correct for that torque tube. The housing broke on this one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2017 at 4:00pm
You have two different tractor put together here.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fenceguy Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2017 at 4:07pm
What numbers on the block tell what yr the motor is?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fenceguy Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2017 at 4:16pm
https://goo.gl/photos/fis7ScnoHKxrSgd18
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2017 at 4:40pm
If water pump is on the head it's a series I or II. If water pump is on the block its a series III or IV motor. Those are the main differences. Most all other engine parts are common.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2017 at 4:42pm
I can't see your pics, but it sounds like Macon rounds has it right. The serial number, square fenders and externally mounted hyd pump are one seventy. 170 tractors started in 1971 at ser number 7500. Could be someone swapped a one seventy tourque tube and fenders on to a d17. Is it 3 pt or snap coupler?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fenceguy Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2017 at 5:07pm
The water pump is on the block. It is a 3 point hitch
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2017 at 7:00pm
Wow you really gotta neat tractor here.
At least three tractor in this one. But I like it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fenceguy Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2017 at 7:09pm
Nt sure yet if I'm gonna like it or not!! Sounds like a pia. Thanks for all the info, I'm sure more questions will arise. I still have to figure out the problems w the starter!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2017 at 7:40pm
Have you had it running ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fenceguy Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2017 at 7:51pm
Oh yea, it was my dad's. I have ran the tractor a lot of years. The injectors and pump were wore out so I decided to do some restoration until all this came up.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2017 at 8:26pm
Front half is a D17, torque tube back is a 170 as people have already mentioned.  Just get your starter rebuilt by a local shop, it eliminates the PIA factor.  Hope your engine doesn't need rebuilding - THAT would be a real PIA!  Good luck with it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fenceguy Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2017 at 8:48pm
Nobody has the head for the starter which is broken. Found one hear in Iowa and the guy wanted 325.00 just for the head. Yes the motor needs rebuilt too, not much compression anymore
