Help - 185 Electrical???
Jim Lindemood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Lindemood Quote  Post ReplyReply Direct Link To This Post Topic: Help - 185 Electrical???
    Posted: 08 Jun 2010 at 7:39am
Have a 185 that won't turnover. Was working fine- parked in barn after bushhogging.
Next day, went to start and it gave a little growl but not turn over. Tried again and just got a click. Next try absolutely nothing happened. Red light comes on when turn key on.
Cleaned all battery terminals, tried jumping from truck -- still not even a sound.
I am looking for suggestion, ideas where to start. Need tractor for round baling hay  - soon. Thought it might be a solenoid issue - AGCO dealership sent a new one, and it is not the same as the one on tractor (won't fit). Not sure that would have resolved the problem. What do you think?   Man, feel like I'm under that little rain cloud. Still have not resolved the 5030 lift issue and now this. My two dependable tractors.
Burgie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2010 at 7:43am
Jim, It is usually that saftey switch on the clutch. You can jump the solinoid on the starter. Had it happen to the on I had.
"Burgie"
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2010 at 8:09am
If you were in brush bush hogging, Its what burgie says. Did you try just jumping from cold post on solenoid? If no sparks try putting the hot jumper cable on post on starter. If nothing there, then its starter problems.
  Clean the connections on the solenoid that sits on the starter, I have had to do that on my XT's too.  Quick test, take a screw driver and make contact between hot post and switch terminal on solenoid, should start cranking. If it does , then its in the switch circuit. If nothing happens then try sticking screwdriver in between cable lug nuts on solenoid and make a quick contact and hold. (make sure the tractors out of gear) If tractor starts, then you have bad solenoid.  Also check the strap that goes from solenoid to starter.
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2010 at 11:11am
If its not the neutral safety switch, check the battery connections and at the starter.  Its probably that miserable Lucas starter gave up the ghost!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2010 at 11:24am
They had them Lucass starters on them? Why did they switch away from Delco? Were they to bullet proof compared to others or were the lucas cheaper?
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2010 at 12:00pm
200s, 185s, 7000s had that miserable Lucas.  Why did they switch-they were cheaper, and belive me they were cheap junk, but the parts werent cheap!!!!!  The field winding wouold short out, what a miserble job replaceing the fields.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2010 at 4:03pm
SO what starter would you put in to replace them if you had a choice.
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2010 at 4:19pm
If you try starting it with a screwdriver make darn sure it's in neutral so it doesn't run you over! Had that happen to a neighbor and it killed him.
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2010 at 4:29pm
JC  Id get a Delco in place of the Lucas,  the Delco is longer, but on a 185 I dont think here are any clearance issues.  On a 200 you have to take the fuel filter or primer pump off to slide it in.
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2010 at 8:10pm
could be bad battery('s)
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2010 at 9:27pm
My 190 had a bad wire in the wiring harness that went from the key switch to the solenoid.  After running a new wire, it works perfectly.
This page was generated in 0.043 seconds.
