Wd disc size
blue924.9 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote blue924.9 Quote  Post ReplyReply Direct Link To This Post Topic: Wd disc size
    Posted: 25 Feb 2017 at 12:37pm
How big of a disc can a wd pull? It is getting rebuilt with 1/8th inch over bore pistons, a 45 crank, and a cam ground to 175 specs. It will be a pulling tractor that I want to try on the disc for fun, it has front, mid, and rear weight brackets so slipping hopefully won't be much of an issue.
hi my names dan, I am a young guy. i have a problem, i prefer my tractors orange and my clutches mechanical, thanks for letting me share
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2017 at 1:31pm
12-14 foot. My CA will pull 8-1/2 foot with ease.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2017 at 1:39pm
Condition of the rear tires (lug height), actual tire size (width and diameter), dual wheels or not, total weight of the tractor, drawbar height, disc weight per blade, un-tiled cornstalk ground versus moldboard plowed ground, etc, etc, etc. Yeah, anywhere from 9 ft to 13 ft.
VAfarmboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote VAfarmboy Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2017 at 2:35pm
I have a 10' AC 2200 disk that I know was pulled with a WD45 by its previous owner.
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2017 at 3:28pm
Uncle Theo told me once that a good WD-45 with duals could pull a SC #215 (15') disc in plowed ground.  If Ted said it, it must be so...
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2017 at 8:44pm
we pull a 14'' with a wd45' with duels in 3\th gear in any kind of ground' works fine' the more you do the better it works
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2017 at 9:05pm
Single or tandem disc? I'd think a WD or a 45 would have trouble with a 15 foot tandem with sharp discs and in plowed ground. You'd need duals at the very least.
DON G View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote DON G Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2017 at 9:28pm
10 ft. worked good for us.
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2017 at 4:39am
Im with the Doc with all of those variables!👍
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2017 at 1:34pm
x2. All those variables play into consideration.
For example....my 8N would probably pull a 1 bottom in a buddy's field (really sticky gumbo that plows like asphalt), but it will pull a 2 in my soil just a few miles away, and it would handle a 3 well in some of our soil at the ranch. It's a sandy loam that plows very easy.
Variables make all the difference.
Mike Plotner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike Plotner Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2017 at 5:40pm
I've drug 14 foot Dunham Lehr and BWF Deeres with a WD that has D-17 guts and loaded 23 degree firestones with good tread
2001 Gleaner R42, 1978 7060, 1977 7000, 1966 190 XT, 1966 D-17 Series IV and 1952 WD and more keep my farm running!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2017 at 9:18am
That's pretty impressive.
