Backhoe Attachment
Bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bee Quote  Post ReplyReply Direct Link To This Post Topic: Backhoe Attachment
    Posted: 24 Feb 2017 at 3:08pm
So I own a used JD 2305TLB.  Nice little guy.  Folds up and takes up minimal space.
looking to get something bigger but not too large.  Series 2 or 3 size.  Without an Aluminum transmission case etc.  Had a question about the Backhoe attachments from manufactures such as Titan, Bushhog, Bradco etc.
The attachments without a model specific subframe that mount on the 3 pt, are they decent?  Will the tractor handle the setup without causing damage?
Or should I strictly stay with a subframe mounting ssystem?
Thx
Bob, North Carolina
1949 B
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2017 at 3:17pm
Does your 3 point have down pressure because without down pressure all your going to have is the weight of the hoe attachment to hold it down
farmtoybuilder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2017 at 3:21pm
Sub frame is best!
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2017 at 9:56pm
and depends on what you plan on doing with it? and Tadams is right, need down pressure 3-pt, or a way to lock it down.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2017 at 9:58pm
also...I see a lot of those 3-pt backhoes on auctions. and every one of them, the controls are shot. the rest of the units are still good, but all the hyd controls must be light duty stuff.
