Hiniker cab wiring on 180
ksbowman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ksbowman Quote  Post ReplyReply Direct Link To This Post Topic: Hiniker cab wiring on 180
    Posted: 23 Feb 2017 at 5:36pm
I have a 180 with a Hiniker cab and the wiring was torn off at some point in time. At the rear the wiring harness enters both sides and was torn apart. I had assumed the main feed would go into the frame work in the front and then run through the frame. Now after looking further I'm not to sure the main wiring didn't come in from the rear and "Y" off both ways, as the only wire at the front I believe feeds a hot to the heater blower. Can anyone shed some light on it for me?
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2017 at 8:51pm
a buddy had a year-a-round cab that the wiring went up thru the rear framework tubes, and I think they then spread out across the cab roof inside towards the front for various things. the wires inside were covered by the cab interior foam and vinyl.
This page was generated in 0.071 seconds.
