Question about driving a dozer
Ferdinand View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ferdinand Quote  Post ReplyReply Direct Link To This Post Topic: Question about driving a dozer
    Posted: 22 Feb 2017 at 9:23pm
I'm sure I asked this question before but, nothing turn up in a Search of the Forum. Anyway,
I've been watching videos of dozers in operation. When the driver has the dozer in gear and engages the clutch; the whole machine jumps. Sort of like dumping the clutch on a car. Except, the car starts spinning the tires whereas the dozer tracks grab the ground and the whole things jumps forward.
The question: Is this hard on the transmission?
Should the driver engage the clutch at a low idle setting and then bring the rpm's up after the dozer is moving?
I know that some IH's have a deccel pedal for slowing the engine when reversing direction.
Maybe not quite the same thing but, there is a youtube video of someone's German Tiger I tank starting from a standstill and suddenly jerks forward. Seems awful hard on the trans. Maybe dozers are tougher than I imagine.
Because narrow is the gate, and narrow is the way, which leads unto life, and few there be that find it.
Mathew 7:14
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2017 at 9:50pm
They move pretty slow so the sudden engagement isn't as bad as appears.If you ever ran a manual drive you'd find yourself jerking it too.Power shift is best.Just hit decelerator as flipping lever and release.There you find yourself using decelerator more softly as you get tired of getting jerked from one direction to the other.Cat P/S were designed to withstand wide open direction changes.The operator gives up before the tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ferdinand Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2017 at 10:22pm
o.k., thanks. I guess they tougher than I think. Here's a video of what I"m saying anyway. The jerk or jump occurs at about the 0:34 mark. Yes, it's a Red machine.Big smile
[TUBE]gC6r1L1IMa4[/TUBE]
Mathew 7:14
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2017 at 11:01pm
Ferdinand, that really was no jump there, more like a little bounce... normal every day happening there..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2017 at 2:00am
If your not already there the guys on the Red power forum would like to see those red machines pushing dirt too!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2017 at 11:15am
One thing to remember is the jump is the engaging of the sprocket teeth with the bushing roller of the track that is stationary .
 It's not like a tire that has power applied to it and either spins breaking traction or throws a shock load onto full driveline .
 Yes it is possible to spin the tracks on a machine when it breaks the track friction to ground surface loading - this is weight of machine x track surface / HP torque applied.
  A good operator knows the load to move + resistance + speed needed / HP available .
To this he applies the power needed at proper time to get the job done .
 You do not attack a pile of dirt starting at the center - but pick at edge and work to fully load blade or bucket .Same digging a hole or dozing area - start light and work up to full loading - watch the guy work the depth of the blade to keep tractor moving .
  There is more to operating a machine than many think - it the case of the IH shown a hand clutch in engaged while other hand controls blade - once machine is moving the steering clutches, brakes and blade depth all are worked to keep power applied without stalling engine.
 In newer machines with power shift and pedal steer it's easier and faster , in fact many machines are now joystick pilot controlled operation.
Edited by Coke-in-MN - 23 Feb 2017 at 11:20am
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2017 at 6:39am
You don't want to feather the clutch too much or you will have a early clutch failure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ferdinand Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2017 at 1:05pm
Thanks for the info guys.
It wasn't so much as feathering the clutch as: do you engage the clutch at a low idle and then advance the throttle or just put the throttle at the high speed detent and go ahead and engage the clutch.
Good to know, if I ever get to own a dozer.
Here is what I'm talking about with a German tank. I think this isn't normal.
At about 2:34.  See that much tonnage jump like that makes me cringe.
[TUBE]ROnb5ouBjNc[/TUBE]
Edited by Ferdinand - 24 Feb 2017 at 1:49pm
Mathew 7:14
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2017 at 6:08pm
If oddball was drivin that tiger, he wouldn't have popped the clutch, on that 1-2 shift.  Gotta remember to think positive thoughts...Wink
[TUBE]http://youtu.be/f5cL-h3Pj1o[/TUBE]
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2017 at 12:24pm
The 2 manual drives I operated,you left the throttle wide open and pulled the clutch in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2017 at 8:49pm
Most older machines did not have decelerators - so engine stays at constant RPM and clutch is used to change direction or gear ratio.
You do NOT slip clutch but ease it into drive - in either direction -
 As one hand is operating lever for blade or bucket - other hand is operating master clutch which allows the other hands to use steering clutch levers as they need to be pulled before using feet on brake pedals .
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2017 at 9:26am
  I agree, that dont look good, thats 52 tons of tank.
