D14 starting issue. UPDATE
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Topic: D14 starting issue. UPDATE
    Posted: 22 Feb 2017 at 6:27am
Having problems getting a 149 started. Engine has new points and condenser, have tried three different carburetors, new wiring, new ignition switch, defiantly getting fuel, very close on timing, new wires and plugs. Engine will fire off while cranking engine very quickly but dies immediately. Have checked to make sure it is getting fire to the coil/distributor in the cranking position and the run position, both are doing what they need to do. What am I missing?
Edited by AJ - 22 Feb 2017 at 8:27pm
Can't fix stupid
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2017 at 6:33am
   Hey AJ,,,sounds like you might have a "short" in the ignition switch that loses contact when you let the key go after it starts,,,try "ole Shameless Trick" and hot wire it,,and then jump across the starter solenoid contacts to crank it,,,,,Clap
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2017 at 7:03am
I have checked current to the distributor and coil during cranking and running. It has constant power. I even tried to run a wire directly from the battery to the coil and had no difference.
Can't fix stupid
SFSutton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SFSutton Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2017 at 7:04am
If there is a ballast resistor in the configuration, it may need replacing.
Good luck
D-14
D-14
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2017 at 7:05am
Is the ignition switch wired correctly? It sounds like both the starter and the ignition are both on the start terminal of the switch.
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2017 at 7:15am
Pretty sure the ballast resistor is inside my coil on this one. Ignition switch has no two wires on the same terminal.
Can't fix stupid
Guests View Drop Down
Guest Group
Guest Group
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2017 at 7:47am
if you ran a wire directly to the coil. that eliminates keyswitch issues. Aj, how about things like distributor sideplay, and then thinking of other scenarios..is the valve clearance too tight possibly?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2017 at 8:00am
Put an ammeter in series with the power to the ignition system. Break connection between coil- and dist points, put ammeter in series there. With ignition ON, and points closed( bump to get them closed) ,you should read 4 Amps on the meter ( say 3.5-4.5). That would be normal. Any less and coil won't make a good spark, any excess and the points will burn...
Now IF the coil is a 12 volt WITH internal resistor AND you still have the original ballast resistor ( on plate with fuse...) then you'll NOT have enough power(amps) going to the coil. You'll get 1-2 bangs then nada...
I've rewired my D-14s to supply solid 12V from switch to coil+, coil- to resistor, to dist points. Makes it easy to check and never had resistor go bad out there.
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote SFSutton Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2017 at 8:03am
I realize you just installed a new condenser, I'm suggesting replacing it.
D-14
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2017 at 8:06am
Have you tried pull starting it. ? Darrel
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2017 at 9:13am
Side play? You mean that literal? Distributor seams snug in the housing? What do I look for when searching for side play?
Can't fix stupid
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2017 at 9:15am
Took the distributor out of a running engine (because I didn't want to waist anytime, just want trying to figure out if the engine is crap or not)  and it did the same thing with the old condenser and points as the new ones.
Can't fix stupid
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2017 at 9:17am
I have not checked the valve clearance yet, the engine hasn't been opened since it came out of the tractor. Didn't think that was a likely possibility. Seems to have great compression.
Can't fix stupid
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2017 at 9:18am
Have not tried pull starting it yet, seems it should run with the way it acts. I mean it starts when you're cranking it.
Can't fix stupid
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2017 at 11:30am
If it fires and 'runs' while the key is in the start position it is not the condenser or point gap or timing. First do what oldorangeiron suggests and run a jumper wire before spinning your wheels on more laborious troubleshooting.
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2017 at 12:34pm
Already did the jumper wire. Same results.
Can't fix stupid
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2017 at 4:18pm
I suspect a short in the ignition switch. Had the same issue with a lawn tractor several years ago. Installed a push switch between the solenoid and starter; + side to battery, - side to solenoid (system was neg grd). Turn the key on and hit the new push switch; started great and kept running when I released the switch...still have the same setup after 5 years. Got the switch from the local NAPA. You test by running a jumper from the bat to the solenoid and another one from thee battery to the coil; touch the jumper wire to the battery, after it starts; remove the jumper wire
Edited by GregLawlerMinn - 22 Feb 2017 at 4:25pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2017 at 4:49pm
Roll the engine over by hand to the FIRE line in the timing hole at #1 TDC. Then with the coil wire off the distributor and the ign switch on, rotate the distributor against the direction the rotor turns slowly until you get a spark from the coil wire. This will get your timing very close to where it should be. If your problem is timing this should get you running.
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2017 at 5:49pm
Already tried to isolate the coil from the switch and starter. Had same result
Can't fix stupid
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2017 at 7:46pm
   Hey AJ,,,as you well know,,,engine has to have two things to run,,,fire and fuel,,,, running a jumper from positive of battery to positive of coil should give you fire,,,so have your can of starting fluid ( WD-40 is better) handy and see if it will keep running while  sprayin into carb inlet ,,,,I'll bet you  a quarter it will stay runnin,,,,,Clap
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2017 at 7:56pm
Already did that trick Joe.
Can't fix stupid
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2017 at 8:12pm
You replaced the wires?  Check to make sure they are on the correct plug and coming from the correct post on the cap.  Also they should be copper wires.
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2017 at 8:26pm
Ok, I'm gonna call this "progress" because I did get the engine to run. BUT it will only run with the choke almost all the way open on the carburetor. You have to hold it there with your finger and adjust it to level out the engine. Now, this is for you LP guys. This is a factory LP engine. I thought I had read somewhere at one time that LP engines are timed differently and have different compression ratings to match the fuel source. In this case would the gasoline not be "rich" enough for this particular engine setup since it was actually set up for propane?
Can't fix stupid
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2017 at 3:22am
     AHA,,,,,,,!!! we're gettin closer all the time,,,,
     You are correct in that the LPG engines did have higher compression ratios ( 9-1 Vs 8-1 for the gasoline mainly due to the lower BTU value of the propane. I do not remember if the different timing setting was specified in the book I had,, but I did wind up havin to set the timing on the 1963 D15 SeriesII LPG "advanced" by about 4 degrees (if I remember right)
    I have always set the timing on all my stuff based on how the engine sounds when reving it up, as well as how easy it starts but always leaning towards setting it more advanced than not as long as it doesn't make for hard starts or get into pre-ignition. The LPG 160 in that tractor liked the 4° advance real good.
   Using gasoline in that LPG engine would be "richer" than the LPG but hard to believe that engine will not stay runnin just cause of the different fuels,,,,,has to be something in the carb you're using,,,,?
   What you have similated is an old Hot Rodder trick to raise the compression ratio  for added horsepower but the carb is just not keeping up with the fuel demands of the engine. I'm puzzled that you say, that you have to hold the choke " almost all the way "open"  for it to keep runnin,,,???
 Having to hold choke partially "closed" is indication of engine starving for fuel,,,,?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2017 at 6:59am
OK, I'm cornfused... this is a PROPANE D14, you're trying to run on GAS ?? Ya shoulda said that in your original post...I ain't got one of them but in reading the service manual I can see they's a tad more 'complicated' than a regular gasser !
I'm betting there's a few 'tricks' to make it run...but sorry to say I can't help ya.
Jay
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2017 at 7:32am
Check intake for a leak where it is sucking in air. This would explain why you have to richen up the mixture to get it to run and also explain why three different carbs did the same thing.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2017 at 7:34am
Engine hasn't ran in a while. I am just trhing to see if the engine needs rebuilt or not. It will be on propane I am just in the middle of re-doing the LP tank with new valves and gauge. Tractor has potential just doing my homework on it.
Can't fix stupid
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2017 at 7:36am
I will do some inspecting Stan, thanks.
Can't fix stupid
bigredisb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigredisb Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2017 at 9:16am
I didn't see it noted but if you are working on something that has not run in a long time and trying to determine if it needs a rebuild, start with a compression test. It will tell you if all the hassle is even worth the effort before you sink hours into it.
I have seen a few people state it takes only a couple of things to get an engine to run but the truth is it takes 4 things. Air, Fuel, Spark, and Compression. Air is a easy one but compression is the most overlooked of all and can tell you the most.
1961 Allis-Chalmers D15
1949 Farmall Super A
