8030 Axle ?
JimWenigOH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Topic: 8030 Axle ?
    Posted: 21 Feb 2017 at 5:22pm
Can someone tell me if the key-way in the axle on an 8030 is tapered or square? I have a set of Unverferth Wedge-Lok Hubs for my 220, and wanted to use them on the 8050. Unverferth said they don't show ever having the wedges for the 8050, and that I could buy the wedges for an 8030 and machine the integral key to fit my 8050. The 3 3/4" axle on the 8050 has a tapered key-way 11/16" wide top and 9/16" wide bottom around 5/16" deep. The wedges I received for an 8030 had a square cut integral key over 1" wide around 1/4" deep. Machinist thought if he cut the key down square it would be OK, but he could taper it if needed. That's why I want to know how the key-way is cut on an 8030 axle. Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2017 at 5:58am
bump
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2017 at 7:47am
If axle is same diameter it should work.     MACK
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2017 at 8:22am
220 and 8030 are 3-5/8 axle not 3-3/4.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2017 at 8:48am
I think the long axle 8030 might be 3-3/4" not 3-5/8.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2017 at 7:34pm
I'll try again. Can someone tell me if the key-way in an 8030 axle is cut square or tapered?
Kevin in WA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin in WA Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2017 at 8:25pm
Tapered just like the 220.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2017 at 6:49am
Thank you.
