HD4/655 - Dump Cylinder Seal Cross - Reference
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Topic: HD4/655 - Dump Cylinder Seal Cross - Reference
    Posted: 21 Feb 2017 at 3:41pm
Anyone have a good source to cross reference the Allis Chalmers (internal cylinder components) - wiper seal, packing set,  o ring and bearing ring.
Working on a 655 Dump Cylinder and need to repack the cylinder with new parts.
Any ideas - suggestions appreciated!
Orangeman
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2017 at 6:30pm
Any reasonable hydraulics shop will have assorted seals they can match up to.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2017 at 9:46am
Minnpar in Mpls -  or Herc-U-Lift in Mpls
Or as parts are fairly standard - a hyd shop in your local area should be able to match what you need.
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2017 at 2:49pm
DMiller and Coke:  Appreciate the insights - I have  Herc U Lift on my list and a few other fluid power shops.
Am still looking for a printed cross reference - someone must have one - but where?
Thanks Orangeman
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2017 at 12:58pm
Ok - touched base with Rochester Cylinder - they advised that there is no industry cross reference available due to variances in cylinder sizes across the industry.  Once the cylinder is apart - easy to match the gland o ring, seals and packings.
HTH's
Orangeman
