Need a measurement
SFSutton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SFSutton Quote  Post ReplyReply Direct Link To This Post Topic: Need a measurement
    Posted: 21 Feb 2017 at 5:36am
What is the outside width of the engine frame on a D-14 and WD? Which is wider?
Thanks
D-14
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2017 at 7:53pm
Not home to check
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2017 at 10:09pm
Is a D14 and D15 the same?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2017 at 7:26am
D-15 and D-17 are the same---- D-14 is narrower by 1 to 2 inches. WD is closer to D-15/17 at about 19?? inches.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SFSutton Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2017 at 7:37am
Thanks, that is exactly what I wanted to know...
Take care
D-14
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2017 at 6:12pm
D-14 is close to 2" narrower.  I bought a 14 with a loader, the loader was shimmed with 2 1X6's, under the front frame rail brackets.  Took loader off, and mounted it to D-15, fit like a charm...
Hyperpack View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hyperpack Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2017 at 9:36pm
WD is 19 1/4 inches wide. I will check D14 tomorrow
Post Options Post Options   Thanks (0) Thanks(0)   Quote SFSutton Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2017 at 3:23am
Thank you for the measurement, I'm all set with the infor already presented.  Thanks again for your efforts.
Steve
D-14
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2017 at 6:31pm
I measured my D14 and it was 17 1/2 inches.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SFSutton Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2017 at 2:55am
Thank you.
D-14
