I-400 (D10)
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Topic: I-400 (D10)
    Posted: 20 Feb 2017 at 7:26pm
I have an I 400 which is the industrial version of D10, It makes an awful groaning noise when backing up, no problem  going forward, where do I start looking. It also jumps out of 2nd gear.
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2017 at 8:48pm
not any help to you but, my sisters d14 is making a noise in reverse as well.
if i pull back hard on the shifter it stops making noise.
not sure if its a bearing/bushing issue on the main shaft.
the reverse idler that the shift fork rides in is just a gear with bushing on a shaft. the actual reverse gear is on the main shaft.
dan
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2017 at 9:00pm
Shuttle shift, or regular transmission?
