Brought another one home...6140
lowell66dart View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Topic: Brought another one home...6140
    Posted: 20 Feb 2017 at 9:04am
I didn't need another project but.... sheetmetal isn't too bad, recent clutch job. Shifts nice, brakes ok. Hydraulics and pto work fine.
Now the problem. Hard stater but I haven't checked to see if the glow plugs are working. Good smoke out of the exhaust when cranking. I think the rings are gone or stuck. It smokes a bit but what I don't like is when I pull the dipstick when running I get a pretty good amout of smoke there. The only ring set I have run accross is $800 for rings, rod bearings and gaskets. This is a Toyosha 2.3 3 clinder diesel. Anyone have any parts sources or advise?
Edited by lowell66dart - 20 Feb 2017 at 9:10am
AC 6080 (8030,7060,200,175,D-17HC, 6040,160,6140 all gone) Farmall 1066 & 656 Hi-Clear (for sale), White 2-62 High Clearance, JD 4255 Hi Clear.
Dean(IA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean(IA) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2017 at 12:25pm
There is a parts source in Texas  but I'm sorry I can't give you a name. It has been many years since I overhauled one. The 5020, 5030 AND 6140 pistons and rings are all the same as I recall.
HTH
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2017 at 1:22pm
Thanks anyway Dean.
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2017 at 2:48pm
Might be just as easy to find a good running engine instead. Didn't Massey use that engine in a couple machines? I could be wrong.
Can't fix stupid
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2017 at 5:42pm
Spent a bunch of time searching the Internet and found two other parts sources today. So parts wise I am good. I started the tractor today and it actually didn't start to bad. Fresh oil and running it might have helped. I want to work it hard before I decide what to do but first I have to change the waterpump. It's got a ton of scary play in it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2017 at 6:30pm
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2017 at 8:50pm
one always had to use the glow plugs on initial start up.   If you pulled the dipstick while running you should have gotten blowby and an oil bath...
does it have hydrostatic steering or assist ps... i.e. a cross cylinder or a swivel mounted on top or the lh front axle. ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2017 at 6:57am
No oil bath, just vapor. The steering has the pivot mounted on top of the axle. Nice beefy setup.I am waiting for my manuals to show up but right now I am letting the glow plug heat up for 30 seconds?
Edited by lowell66dart - 21 Feb 2017 at 6:58am
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2017 at 11:12am
There are a boatload of used parts on ebay right now.  Somebody appears to have parted out an entire pair of 6140 tractors.  Some of the prices seem great, others seem a bit high, but I would jump on them if I needed them.
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2017 at 12:17pm
I saw that, thanks. My water pump should be here Friday so after that is fixed I am going to drive this thing a bit and decide what to do. I think I can get rings, bearings, seals and gaskets for about $700. Then head work. I am waiting for my shop manual. Anyone know if this is a drop pan/pull head repair or does the tractor have to be split?
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2017 at 8:09pm
AJ a friend of mine has a three cylinder Massey and it has a Perkins in it. In fact he just overhauled it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2017 at 6:55am
This has a Toyosha engine from Japan. Out of business now. The tractor was made by Hinimoto for Allis. Massey did use the same engine in a few models. TBN has a nice Grey Market forum and the Toyosha engine and tractor are well thought of from what I read.
My water pump came in yesterday so I may be able to get that done this weekend.
Edited by lowell66dart - 22 Feb 2017 at 6:57am
