190 gas rebuild
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Topic: 190 gas rebuild
    Posted: 19 Feb 2017 at 7:59pm
I know this has been talked about before that a g2500 and g2800 use the same block, but different crank and sleeves and pistons. Is there any reason why a g2800 rebuild kit for a 190xt wouldn't work in a straight 190? Bigger bore, it just wouldn't stroke as far? The g2500 kit is $1000 more if I can even get it.
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2017 at 8:07pm
them old' good running 190 around hear are 2500 or less. it's hard to get anything out of them tractors' hard to put a lot in one of them.
Larry W. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry W. Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2017 at 8:40pm
7060 I messaged you
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry W. Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2017 at 8:41pm
301 gas pistons + 2500 crank makes LOW compression
Norm Meinert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Norm Meinert Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2017 at 9:43pm
If there in enough need for the g2500 engine kit I can build some. I will have d-19 gas engine kits at Booneville. If you need one let me know what size bearings you need.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2017 at 10:03pm
Best thing to do is buy a 301 crank and 301 motor kit.   MACK
This page was generated in 0.052 seconds.
