AC roller
Ranse View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranse Quote  Post ReplyReply Direct Link To This Post Topic: AC roller
    Posted: 16 Feb 2017 at 7:32pm
Does anyone know anything about an AC round bailer? I didn't even know they made one. My neighbor said he had one that he'd give me on the condition that I restore it. He didn't say a lot about what shape it was in other than it was stuck and wouldn't turn. I'm not sure I'm up to that kind of challenge. I need another project about like a hole in my head, but I can't wait to see this thing. I'll post more information when I find out. Thanks
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2017 at 7:38pm
One of the simplest balers ever made. Very simple to run and operate. If I was there I would be glad to help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2017 at 7:43pm
There was the little one, that they made thousands of, 40's-70's and a bigger one built by Hawk Built, but it was a ground driven flop, that couldn't roll a tight bale...
A white top (late model) would be worth a go, but the older units are mostly give-aways, now...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranse Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2017 at 7:58pm
That explains why he's giving it to me I guess. I reckon it is the little one from the way he described it. I'm not sure what I'd do with it if I did have it in good working order.
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2017 at 8:14pm
I had one and baled thousands of bales with it!----Didnt have an ac at the time, so I used one of my super M'd tractors on it and got along excellent with it!----wish I had the baler back! thanks; ac fleet
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2017 at 8:14pm
Go for it Ranse! Once you start working on it, you won't be able to stop until you have it working like a Swiss watch. And once you get it working, and baling with it, you'll be out begging people to let you bale for them. ........Ok,a little exaggeration there, but I do thoroughly enjoy mine. It is not my bread and butter by no means, but running it is a good stress reliever. Darrel
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2017 at 1:09am
and Darrell has ALOT of stress up there!
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2017 at 7:50am
I think Allis built around 75,000 of those round balers
Wink
I am a Russian Bot
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2017 at 8:28am
We ran several of them for years,hope you can find someone thats run one to show
you the ins and outs.And buy a set of those red hay hooks at TSC to handle the bales with and keep one on the baler to unplug hay and to latch the rear springs.Never ever
start to bale unless you have made sure the brake is loose and not stuck.It can stick overnight.
FloydKS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FloydKS Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2017 at 9:27am
Yep,,. if you fix it the brake should be checked before use, even humidity for a night can make it stick... and yes there are some 'sticky wickits' that are tricky to make work unless you know what to look for...but they are a fun machine to operate and watch work. go for it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2017 at 9:30am
Hmmmmm. Wonder where the stress comes from. ....? Possibly from too much snow. ..? Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2017 at 12:56pm
Naaawwww.........it CAN'T be that can it? Wink
