Turbo
200 allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200 allis Quote  Post ReplyReply Direct Link To This Post Topic: Turbo
    Posted: 16 Feb 2017 at 7:08pm
Has anyone ran hx40 with 12cm exhaust housing on 301. Still using roosa just curious.
O.P.S. Heads View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2017 at 10:41pm
Which Roosa pump do you have? How many cc's? what size is the compressor inlet and the exhaust wheel on the HX40? Is this open RPM or a 3,000 RPM limit?
HX 35's work well on a 301. A 40 probably would to depending on the answers to the questions above.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200 allis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2017 at 2:08pm
Still running 390 head 3,000rpm. Problem egt still high with water injection. I was talking to a guy that specializes in holsets and he recommended a hx40 with 12cm. Exhaust housing. He think me running hx35 with 55,60 lbs boost that I'm losing power.I was just curious if someone had try a 40 and he recommended using waste gate on 40 to.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2017 at 5:51pm
How much boost can a stock connecting rod take? Unless yours are hardened, I've always heard 45 lbs of boost is the limit,,
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200 allis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2017 at 5:53pm
Max Simpson harden my rods
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200 allis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2017 at 5:54pm
I had bent a rod but that was do to a timing issue
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2017 at 9:16pm
Your turbo guy could be right but before you jump to an HX 40, do you have the biggest HX35 available as far as wheels go? There are a few combinations.
I think a 40 would work well with a .450 head and rotor. With you .390 I'm not sure. Not many people have tried it (including myself) or they would respond to your post. Your just going to have to try it too see if it works or not. Not sure what your rules allow but an air to water intercooler allows you to run a bigger turbo. That would drop your EGT's as well.
For comparisons sake, I know a guy running an 2.5 inch inlet HX50 with the 3.03 outlet. With around 450 cc's out of an inline pump and an air to water intercooler it works really well and lugs like crazy. It is an open RPM class.
Beirnesy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Beirnesy Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2017 at 8:28pm
How about, or has anyone here used a Borg Warner S200, or S300 supercore on there 3000 rpm 301 Allis?
1969 220,1967 190DXT,1968 190DXT, LGT's 710,,716
goomer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote goomer Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2017 at 4:51pm
I run the s200  sx-e super core with 1.00 exhaust housing.  only two hooks on it last year though so dont have much input. Run a  touch over 3000 rpm, 450 roosamaster, 7th gear, 18.4-38's
Post Options Post Options   Thanks (0) Thanks(0)   Quote O.P.S. Heads Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2017 at 4:55pm
180 or 190? What weight?
Post Options Post Options   Thanks (0) Thanks(0)   Quote goomer Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2017 at 5:42pm
190xt  6500lbs
bsallis180 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bsallis180 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2017 at 8:18pm
The s300 is going to be in the neighborhood of the hx50. All that have them around me is greater then 450cc of fuel and 400ci or greater. If you are allowed a intercoolers run one. I have one that maybe for sale
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200 allis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2017 at 6:33pm
I'm running 7th gear 7500 I installed an ice intercooler. I was going to get a 14cm for my hx35 and try that but this turbo guys seems to think I'm going beyond it so he recommended hx40 with 12cm and use waste gate.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200 allis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2017 at 6:35pm
I thought about s300 but there are a lot of different setups for that turbo.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200 allis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2017 at 6:46pm
YouTube Mike menegus tractor pull and under 2016 hunderton county fair pull is a d21 that pulls at are club. Sorry don't know how to get videos up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Beirnesy Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2017 at 7:22pm
https://www.youtube.com/watch?v=BhM_O54vv4g
Is tha D-21 running twin turbo? She's a Wild Thing
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200 allis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2017 at 7:32pm
Single turbo
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200 allis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2017 at 7:34pm
He has been trying to beat that John deere 4430 that goes first. He has been getting close
Post Options Post Options   Thanks (0) Thanks(0)   Quote bsallis180 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2017 at 8:46pm
https://youtu.be/RYZg8HFCvB0
This page was generated in 0.130 seconds.
