horsepower needed for disc? |
| Author | ||
Tracy Martin TN
Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10839 |
Topic: horsepower needed for disc?Posted: 16 Feb 2017 at 11:39am |
How much horsepower need for offset disc,6 1/2 foot, 100 pounds force per blade, 18 , 22 inch diameter blades total? Soft ground and turf? Thanks Tracy
| Sponsored Links | ||
allisrutledge
Joined: 30 Mar 2010 Location: SurgoinsvilleTN Points: 1360 |
Posted: 16 Feb 2017 at 11:59am |
Tracy, someone else may answer better but there is a lot of conditions that make a huge change in requirements .weight of the tractor and tire condition ,also is the pitch adjustable on the disc? I got a case (Burch)offset 12 ft wide ,26 inch blades.8010 is not enough at 100 up and 13000 lbs. 210 got the power but needs more tires. I am looking for duals now. 8010 will pull it. But a little more than it needs. Soil condition had a lot to do with it also. There may be a scientific answer but that is the best I can give. The hills and the clay here is something else. Scott
allisrutledge
Posted: 16 Feb 2017 at 12:01pm |
And always remember too much HP is never a problem!!!
Stan IL&TN
Joined: 13 Sep 2009 Location: Elvis Land Points: 6730 |
Posted: 16 Feb 2017 at 12:48pm |
Less that 500hp will work. Sorry that wasn't much help Tracy.
1957 WD45 dad's first AC
1968 one-seventy 1956 F40 Ferguson |
Jim Hancock
Joined: 11 Sep 2009 Location: EL Reno, Ok. Points: 1112 |
Posted: 16 Feb 2017 at 1:01pm |
Tracey,
Years ago, it was noted generally at 10hp per foot. At least. And that seemed to hold pretty well right on. Our XT's pulled the 10/11' "plowing disc" good with weighted drive tires & duals on. We knew that something was back there, too.
![]() Edited by Jim Hancock - 16 Feb 2017 at 1:11pm |
How blessed we are by HIS GRACE!
sjerden
Posted: 16 Feb 2017 at 1:05pm |
I pull a 9 foot disc with a little Allis Chalmers WD, 45 hp
![]() Edited by sjerden - 16 Feb 2017 at 2:12pm |
Gary Burnett
Joined: 11 Sep 2009 Location: Virginia Points: 3101 |
Posted: 16 Feb 2017 at 1:56pm |
Lot depends on how fast and with each pass it takes more HP. I have a Massey Harris
9ft offset disk and it'll give the D19 all it wants. |
Gary Burnett
Posted: 16 Feb 2017 at 1:57pm |
tadams(OH)
Joined: 17 Sep 2009 Location: Jeromesville, O Points: 11033 |
Posted: 16 Feb 2017 at 2:24pm |
Being soft ground you will probabaly want duals on what ever you use.
sjerden
Posted: 16 Feb 2017 at 2:28pm |
Gerald J.
Joined: 12 Sep 2009 Location: Hamilton Co, IA Points: 5636 |
Posted: 16 Feb 2017 at 3:11pm |
I took the gangs off of an Oliver 232 12' disk. I mounted two gangs as an offset disk using some 4" wide flange steel beams under the main frame. I pulled it for years with my MF-135. It pulled as hard as the 2x 16 Case plow that I have. That was in freshly spring plowed black soil.
Years later an old timer neighbor told me it was beneficial to pull a disk 8 or 9 mph because at that speed the disk would toss weeds up in the air and they would land bare root on top the ground a dry out the roots and die. By that time I was working the ground with my 4020 and I acquired a 20 or 24 foot disk with folding wings. I used parts from the wings to rebuild the center gangs leaving it about 14' and it was a good load for the 4020 at 9 mph. I had to lock the differential to keep the 4020 from hopping side to side. Gerald J. |
CALEBnOK
Posted: 16 Feb 2017 at 4:18pm |
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54423 |
Posted: 16 Feb 2017 at 5:30pm |
And the answer is, 20 HP, like a ferd has will pull it. 25 is better fer speed, and 35 better still...
BradH
Joined: 28 Feb 2016 Location: Corydon Ia. Points: 264 |
Posted: 16 Feb 2017 at 5:49pm |
A few years back we pulled dad's 14 foot Bush Hog offset to break up some bottom ground sod. Put it on the JD 4440, like new tires, duals, and 1000 lbs. on each rear wheel. It was a little wet but we had to get the job done. You could just barely feel it but it was pulling the tractor off in one direction while it worked. He always told me that disc had a tendency to want to corkscrew as it went through the field. I don't know though, I never ran it myself. I guess you may want to think about your tractor weight situation, depending on the job. Just my thoughts though.
Later, Brad |
Warning! Blind man with a tractor! Head for the hills!
Tracy Martin TN
Posted: 16 Feb 2017 at 8:47pm |
This is an Oxnard built AC offset disc. Looks like it will cut the ground well. I figured if the 170-175 wouldn't pull it, the 185 would. Thanks Tracy
Allis dave
Joined: 10 May 2012 Location: Northern IN Points: 3074 |
Posted: 16 Feb 2017 at 9:21pm |
We pulled a 18' offset with a 160hp 4wd tractor. It pulled a lot harder than the white 24'. But was ok.
160 divided by 3 would be 53. A little under 10hp per foot. So I bet the 175 would pull it. Like you said 185 would for sure |
victoryallis
Joined: 15 Apr 2010 Location: Ludington mi Points: 2878 |
Posted: 16 Feb 2017 at 9:33pm |
Speed and discs never mix ever. Speed and field cultivators or finishers is a better combination.
DiyDave
Posted: 17 Feb 2017 at 5:08am |
Whoops, mis-read the post, thought it was a regular 4 gang disc... Needs at least a 185...
Kurt WI
Joined: 19 Oct 2011 Location: Cascade WI Points: 3242 |
Posted: 17 Feb 2017 at 5:56am |
I had a Miller 10.5 ft off set disc and on my hills it made my 8050 w fwa work! The guy I got it from pulled it with a 6080 fwa and a 190 with duals. When I told him I was gonna pull it with the 8050 he laughed and said your gonna pull the disc apart! Well he had all black flat ground and I got hardpan hills. With the 8050 in front I was able to move it to full angle and it sure was aggressive cutting.
WD D17D 170 190xt 190xtIII 200 7020
CALEBnOK
Posted: 17 Feb 2017 at 7:51am |
Let the drawbar swing if it has a swinging drawbar. If you clamp it down it will make the tractor pull sideways
Eldon (WA)
Joined: 11 Sep 2009 Location: Spokane, WA Points: 7765 |
Posted: 17 Feb 2017 at 10:28am |
ALLIS EXPRESS!
This year: |
Bull
Joined: 28 Sep 2010 Location: Lamar, Missouri Points: 589 |
Posted: 17 Feb 2017 at 11:05am |
We used to pull a Bush Hog 6 foot with a 170 diesel , it pulled it fine.
WD45 Diesel, RC,CA,IB, B, G, 616, Early B-10, D-10, Terra Tiger, 95G spreader, SC blade
jiminnd
Joined: 16 Sep 2009 Location: Rutland ND Points: 2307 |
Posted: 17 Feb 2017 at 12:25pm |
If you go 8 mph you better not have any rocks, around here it would last 1/2 an hour and be destroyed.
Ted J
Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18943 |
Posted: 17 Feb 2017 at 12:29pm |
NOW I know how Eldon changes his front tires!!
Travis2766
Joined: 26 Aug 2015 Location: Amherst, Wi Points: 439 |
Posted: 17 Feb 2017 at 3:16pm |
My dad pulls an 7 1/2' Case offset (24" blades I think) with a 190, used to pull it with a 175 diesel but it was a workout. It all depends on the soil, heavier soil needs more power.
190XT Series III, D17 Series IV, D15 Series II, All Crop 66, Rotobaler.
ctbowles 58
Joined: 12 Aug 2016 Location: CLARKSVILLE MO. Points: 129 |
Posted: 17 Feb 2017 at 6:54pm |
we used to pull one like your talking about with a WD45 weighted heavy
. "the tractor weighted heavy that is". Edited by ctbowles 58 - 18 Feb 2017 at 4:19am |
DennisA (IL)
Joined: 11 Sep 2009 Location: Ridott IL. Points: 2075 |
Posted: 17 Feb 2017 at 7:56pm |
Here's a video of my "CA" pulling a model 20 8-1/2'' mounted disc with 16" blades. My "CA" puts out about 29hp. [TUBE]NoTgpV89jOc[/TUBE]
Edited by DennisA (IL) - 17 Feb 2017 at 10:08pm |
Thanks & God Bless
Dennis |
Brian F(IL)
Joined: 14 Sep 2009 Location: Paxton, IL Points: 2720 |
Posted: 18 Feb 2017 at 7:29am |
Dennis, I remember that day. It was at Ted's AC Jamboree several (10?) years ago. Brian
