B210 Air Filter
minerfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote minerfarmer Quote  Post ReplyReply Direct Link To This Post Topic: B210 Air Filter
    Posted: 15 Feb 2017 at 7:28pm
I have a B210 with a Briggs 243431 engine that has been setting about 6 years. Took the air cleaner apart and the foam element had turned to mush. Any body know where to get a paper element with a foam precleaner for this engine.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2017 at 4:48am
Original filter is all foam, saturated with oil.
Gary
ACmowerguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmowerguy Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2017 at 7:02pm
The later Cast-Iron Briggs had paper filters. You can use a paper filter with the foam pre-filter but will need to change out your air cleaner mounting stud in the carburetor as you need the longer one.
