SunStar engine Pulsing
tractorman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorman Quote  Post ReplyReply Direct Link To This Post Topic: SunStar engine Pulsing
    Posted: 13 Feb 2017 at 8:18pm
I have a Sunstar with the kohler 2 cylinder engine,  the engine  wants to pulse , i mean the engine slows and then the governor opens up to speed it up.  happens as soon as the engine warms a little.  it coninues as long as the engine is running .what can i do to find and fix the problem ?
Play on 38 B 49 WF , working on D14, D15 B10, Bee 12 B110. use 185 and 190
Jim Hancock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Hancock Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2017 at 10:16pm
Sounds like it's running a little lean.
I'd open up the idle mixture some more.
Also, add a very healthy dose of ChemTool B-12 to clean out the carb to be sure it's not a contributing factor.
How blessed we are by HIS GRACE!
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2017 at 11:53pm
needs more fuel' had one do the same' not getting any gas.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorman Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2017 at 5:49pm
could   a   bad or leaking  head   gasket  cause this type of problem ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2017 at 8:11pm
some have a fuel pump' maybe the pump it blocked up' or bad.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorman Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2017 at 8:39am
new  fuel pump, and working - tested .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Hancock Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2017 at 7:00pm
Have you gotten to your engine & smoothed out yet?
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorman Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2017 at 8:22am
no, suggestions ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Hancock Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2017 at 3:03pm
Have you opened up the fuel mixture screw a quarter turn and added a good dose of Chemtool B12 to your gas?
I only asked since we hadn't heard back from you whether you got it running better or not.
I'm also aware that you may have gotten busy with life and just hadn't got to it yet.
So, I was just curious.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2017 at 5:17pm
he must have it fix'
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorman Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2017 at 6:30pm
nope, haven't  a fix  yet.   have tried opening the  needle valve but no luck ther,   chemtrol  is next
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorman Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2017 at 8:02am
i done, tried all the helpful suggestions, no luck.
put on trailer and headed to a repair shop, trailer flat tire on way,  after a trip home for replacement tire,  it is now there.  he only repairs no new sales .   it may also be for sale soon, i'll   post it   if so .
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2017 at 6:36pm
what was wrong with it'''
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2017 at 7:58pm
Sounds like dirt in the Carburetor causing a lean condition as Jim mentioned. That's usually what the problem is when they "hunt" like that....
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2017 at 9:49pm
yes' it's dirt' or a week pump' your right' young man.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Hancock Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2017 at 1:13pm
Have you found out what the issue was yet?
Or, is it still at the repair shop?
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2017 at 7:37pm
mite of got MAD'' an sold it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorman Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2017 at 9:49am
no   not  sold  yet,   still thinking about selling  it.    in  the mean   time  i took   it to a repair  shop,   the   trip  with  it  cost  me  a trailer tire and   a  tough   time  getting  it  fixed.   was   told  aweek   for  diagnostics.   when  i git home the  truck   brakes  went out  so  no truck   now.  and  into   4th  week  with   no estimate  yet.
Selling  sounds  better   all the time      i'll   keep you  all posted  .
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorman Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2017 at 7:04pm
Sunstar   diagnosis    the  governer  was off  a just a little  (me  ?  )    the plugs  were gapped way too wide  ( me ? )   still surges  need to do  the carb   $150  deepening   on whats found    ,     told him to fix  it  .    Truck/   a 93 chev blazer was towed in  today  2  brake hoses  and one  brake line,   no   bill   yet  .    trailer still needs  tire  replaced   .
Sounds  more   like  sell it  ,   will continue  when   all is done
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorman Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2017 at 9:10am
one   last   update
    Simplicity  Sunstar  up  date   its back   and now  runs  good
the mechanic   adjusted out  of  sync  governor,   reset the incorrect gap  on  the plugs   cleaned  and  set   the carb  ,   thanks to  him.   only mishap as a dead battery in  my truck  had  to jump start it to get home.    now   the question    will it  be  for  sale ?
i have  5  other mowers  including   one out on  loan,  3   that run   and one pieces  in rebuilding  one  of   which   is  brand new  .       I could   use  the space in  the shop  .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Hancock Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2017 at 11:53pm
Glad to hear the good news that it's back to running smooth again! Big smile
