175 wiring to temperature gauge
bent wheel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bent wheel Quote  Post ReplyReply Direct Link To This Post Topic: 175 wiring to temperature gauge
    Posted: 13 Feb 2017 at 4:06pm
I'm trying to fix up a much neglected diesel 175. All the gauges are toast and the wire cluster cut and apparently taped at one time so the first thing I want to do is hook up the new AC  temp gauge I bought. The terminals are marked B and T. The sender has a green with white stripe wire attached to it that leads off and up to the cut gauge  bundle. To me B means battery or power and the T means.....haven't a clue. I wired the T to the sender and the B to the power but the gauge pegged to hot so I reversed the connection and there is no response at the gauge after driving for about 15 minutes. I'm wondering if the sender is toast as well. My manuals aren't of much help. Any suggestions or guidance much appreciated, particularly what the B and T terminals on the gauge mean and a reasonable way to use a meter to test the sender.  Thanks much   Tom
AC 175D w/case 70 loader & gannon   "Big Alice"
S/C 18GT "Lil' Allie" w/ blade , disc, MB plow, culivator, got raw land, Big alice tears it up, lil allie makes it pretty
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2017 at 5:56pm
"T" means "temp sender". You had it wired up correctly the first time. Make sure the sender doesn't have any teflon tape wrapped around the threads. Most temp sending units need to be grounded. They establish their ground when you screw them into the manifold or cylinder head. If taped, the tape acts as an insulator and the gauge will react the way it did because there is no ground.... HTH
Post Options Post Options   Thanks (0) Thanks(0)   Quote bent wheel Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2017 at 7:04pm
sounds good, it is however as it has been for many years but it is quite possible that the connection to ground is poor considering the condition of the cooling system in general. Thanks for the info.
