Axle size
allisrutledge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Topic: Axle size
    Posted: 13 Feb 2017 at 10:45am
Will a 7050 axle mount dual fit a 210? I think it is a late 7050. Scott
ILGLEANER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2017 at 10:48am
7050s all had the same size . Is it a 2 clamp or 3 clamp ? Is there room for it to go on ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2017 at 11:06am
It's 400 miles away . I can get the factory duals but I need them on a 210. 7050 is a non running tractor. Scott
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2017 at 11:08am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2017 at 12:02pm
Both are 3 5/8" axle size.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2017 at 12:17pm
Thanks
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2017 at 8:16am
I have the Mexican hats on my 220. If you have 20.8 radials, you will need power shift rims on the duals to get some space between the tires on the ground.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2017 at 11:10am
Calvin, what's the weather like? Our electrical guy is is in your area. I got out of it this time. I'm on the trail of some hats now. I will post the outcome. Scott
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2017 at 1:39pm
Scott, I don't know what the weather is like ! Left home Sunday afternoon and had to get off the road in Erie PA Sunday evening because of blinding snow. 81F , cloudy, with a strong breeze here in Port Charlotte FL.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2017 at 2:01pm
You didn't blow your horn when you went by!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2017 at 7:44pm
Too far away for you to hear !! Drove I-79, 19, I-77, I-26, I-95, I-4, cross country to Port Charlotte  Going home I-75.
