b front pulley help
phillip t View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote phillip t Quote  Post ReplyReply Direct Link To This Post Topic: b front pulley help
    Posted: 12 Feb 2017 at 7:54pm
hey guys, im trying to put a new front seal in my 48 b but im not sure how the front pulley comes off. i have taken the nut with the screw in it out of the side of the pulley.was going to put pullers on it, but i just had gear pullers. they wont work. i dont want to do the wrong thing and break something. i need an expert.    thanks for any help.  phil
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2017 at 8:22pm
I wouldn't put pullers on unless you were very gentle because they could break the cast iron pulley. Mine luckily slid right off after I loosened the set screw. I've heard many aren't so lucky. If it were me, I'd try heating the hub of the pulley, trying to keep the heat off the crankshaft. That should expand the pulley so it may slide off easier. You could also try tapping it with a hammer, just be careful you don't break the pulley.
On a second note...I have used pullers, just put them on and snug them a tiny bit. Then gently tap the center of the pulley. If it moves a little, tighten the pullers a bit more. Sometimes if you're careful, that will work.
Others will chime in and share their experiences and advice.
Edited by CrestonM - 12 Feb 2017 at 8:24pm
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2017 at 9:11pm
Put  bearing splitter behind the pulley and pull on it.
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2017 at 9:24pm
They have two setscrews one under the other.I removed setscrew and put pry bars on each side behind and pryed close too center of hub.Penetrate good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2017 at 1:28am
Originally posted by wfmurray wfmurray wrote:
I put pry bars on each side behind and pryed close too center of hub.Penetrate good.
This works well, too!
Mine only had 1 set screw. Guess I got lucky.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2017 at 5:43am
Heating the hub some will not hurt either.
BenGiBoy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BenGiBoy Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2017 at 7:59am
I just put the pulley puller on it and cranked..... of course I did have two spares if that one broke. But I wasn't worried about the pulley breaking, it didn't even seem like it stressed it too much when I was pulling it. If I remember right it wasn't super hard to get off.
'39 Model B
Tractors are cheaper than girls, remember that!
