JD 310 se backhoe
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Topic: JD 310 se backhoe
    Posted: 09 Feb 2017 at 9:58pm
Anybody know anything good bad, problems? 1 locally 4x4 -extenda hoe looks like it needs tires but no problem for an old tire man. I know wrong color, but you guys have experience with all brands.
jorstad brothers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jorstad brothers Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2017 at 10:33pm
we have one its been good. put a reman engine at 7000hrs do to a cracked head. other than typical wear, there tuff. the cab not great it like sitting in a green house. its not bad on fue land starts good.
remember plunder than burn
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2017 at 3:35am
if it has a shuttle lever on the dash, they will tend to freeze up when they sit awhile. and the extend cyl is inside the arm, if you ever break a hose inside, it's a *ucker to work on! tires only need to hold air, as they are usually up in the air while digging with it. and if you slip and slide or gits stuck, the hoe will pull you out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2017 at 8:12am
there's a 310 on feb 22 auction on big iron
