turbos
JPG AUSTRALIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JPG AUSTRALIA Quote  Post ReplyReply Direct Link To This Post Topic: turbos
    Posted: 09 Feb 2017 at 8:24am
ok turbo gurus,the r62 needs a new turbo(not rebuildable) and the turbo shops all want $2500 to 3000 for one here.I have seen a lot of holsets the same on ebay I can get shipped in as low as $500 but none have the same part number.Mine is a hx40w with a 3535617 number.The closest number to mine I have found is a 3538215 ,they all look identical on ebay apart from that last number.Is there much difference or can the waste gate be adjusted to suit my application. thanks for any replies.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2017 at 8:35am
I'd be thinking looking at one from a similar year/similar HP/similar RPM Case/IH Cummins combine engine. You are talking Cummins, right ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote JPG AUSTRALIA Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2017 at 8:52am
yes talking 8.3 cummins,not sure if the case/cummins are the same turbo or not.I know those engines are slightly different to the real cummins as I needed an injector line last year and the 2388 I tried to get one of at the wreckers was not like mine at all.Unfortunatly there are not many r62 wrecks to pick from and when there is they want to sell the motors complete.
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2017 at 8:58am
maybe someone here in the states can get you one and ship it to you a lot cheaper than what they cost you there?
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2017 at 9:19am
Get the ser#, model # and CPL# off your engine call your Cummins dealer with the INFO and get a price and part # then start looking for that part number.
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2017 at 11:13am
Check this out....
http://www.invasionautoproducts.com/turbo-industrial-cummins-tc-hx40w-3535617.html
Or just the rotating parts:
https://www.amazon.com/TKParts-Cartridge-3535324-4027612-Cummins/dp/B01LWYY9HQ
Edited by TramwayGuy - 09 Feb 2017 at 11:19am
randy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2017 at 12:23pm
Check with Inpumped. He got one for my 8.3. Matched the numbers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JPG AUSTRALIA Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2017 at 5:44pm
Thanks for the replies,🙂
