serial numbers
hotwire View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hotwire Quote  Post ReplyReply Direct Link To This Post Topic: serial numbers
    Posted: 08 Feb 2017 at 11:39pm
i was wondering if someone could help me out my serial numbers? i have a 8010 powershift 2wd with #2826 meaning it is the 6th one from the last? last serial on tractor data is #2832? i have a allis 200 with #11169? tractor data says started at# 1001 and made 10126 200's? where or what is the last serial number because that don't add up to be right?
wayneIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayneIA Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2017 at 12:29am
Sounds correct on your 8010, a possibility on the 200 is that maybe the torque tube was broke and replaced with one off a 190 XT.  It should have the model stamped with the serial number on the torque tube.
Daehler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daehler Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2017 at 7:12am
According to info in swinfords book, your 8010 is right. Tractor data is wrong, book shows 11521.
Post Options Post Options   Thanks (0) Thanks(0)   Quote hotwire Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2017 at 7:32am
no it is stamped as being a 200 there on the torque tube
