314 With electric lift.
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Topic: 314 With electric lift.
    Posted: 07 Feb 2017 at 1:56pm
#1 lift seems very slow.  Is that normal?  It takes about 12 seconds or so to lift the tiller from fully down to just clearin the dirt
#2  Tiller belt.   Anyone have the number for the correct belt?  Mine is quite a bit too short and I have to leave a pulley off to make it work, and if I lift too high the belt hits the body.
#3  Is there no way to disengage the tiller after belt is installed?  My 712 had a separate clutch, but there is not one on this tractor.
JImD
Jim Hancock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Hancock Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2017 at 2:12pm
Hi Jim.
Yes, the lift does seem a little slow.
I'm looking at one now with 150# of force from progressiveautomations.com to lift my Sears Rotospader.
I'm guessing that it's weight with the engine is "about" 100-125#.
This lift travel is .59"/sec.
What does your rototiller weigh? That might be a factor in it's lifting speed.
They can customize a linear actuator for your needs if needed- for a $50 customization fee - as they have basic models already set to ship.
I can buy another one that'll do the job, too, for more $$, but it'd be an overkill lift.
Can't tell you about the belt issue. Sorry.
Edited by Jim Hancock - 08 Feb 2017 at 2:20pm
How blessed we are by HIS GRACE!
This page was generated in 0.191 seconds.
