7020 Pto help
AC200Puller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC200Puller Quote  Post ReplyReply Direct Link To This Post Topic: 7020 Pto help
    Posted: 05 Feb 2017 at 3:04pm
Working on a 7020 pto don't slip and starts up fine but won't let me shut it off resistance on the lever, shut tractor off and pto drops out and does not turn. Replaced the valve with another one and same problem. Low pressure standby is at 600 no matter where the rpms are or weather pto is on or off. Really turning into a head scratcher!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2017 at 4:48pm
Remove the console top covers. Remove the PTO cable anchor bracket and clamp it in a vise. Straighten the anchor bracket back to 90 degrees and weld a brace across it so it won't bend again. Reinstall and adjust cable length so the PTO lever is clear forward in the gate when engaged. Problem solved.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC200Puller Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2017 at 7:19pm
Got it Doc, Thanks for saving me again. And after you said that I remembered that I had done one other one like that.
This page was generated in 0.043 seconds.
