Spray paint vs. gasoline
1939Dodge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1939Dodge Quote  Post ReplyReply Direct Link To This Post Topic: Spray paint vs. gasoline
    Posted: 05 Feb 2017 at 1:33pm
I have to repaint my gas tank. Need a small quantity of paint. Will use a can of spray. Recommendations for paint that will hold up against an occasional shot of gas?
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2017 at 1:41pm
oil base with a clear coat on top
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2017 at 6:04pm
Rattle cans don't have hardener in the paint.  I'm not sayin don't do it, just don't expect miracles...
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2017 at 6:40pm
IF you can't 'clear coat' then once the paint is good and hard, put 2-3 coats of hand rubbed car wax on the tank,buffing well after each coat. It'll fill in any voids and gas will roll off PDQ !
Jay
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2017 at 8:59pm
Rag in hand helps.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2017 at 9:41pm
For electronics projects I've had good results with rattle can Rustoleum sometimes making panel labels with india ink covered with another later of clear Rustoleum and then baked for an hour or so at about 180 degrees F. The baking makes it set up really hard and resistant to wear.
Gerald J.
This page was generated in 0.314 seconds.
