Bought my first AC equipment Friday
Carl(NWWI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Topic: Bought my first AC equipment Friday
    Posted: 06 Jun 2010 at 12:06pm
i bought 2 sickle bar mowers for 350, a digger for a 100, and the plow was a gift. Help with model numbers would be appreciated.
DREAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2010 at 12:14pm
Nice load of equipment! I especially like the "gift". 3 bottom SC plow is very nice! Bottoms look to be in very good shape, as well as coulters.
omahagreg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote omahagreg Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2010 at 12:14pm
Looks like a nice load of some nice stuff!
Greg Kroeker
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2010 at 12:29pm
Carl, The mowers are #3's.  They were a rear mounted mower that fit the WC, B, C, CA, WD, and WD-45.  It appears you have the mounting brackets for a WD or WD-45.  It also appears you have most of the necessary parts.
I have trouble identifying the mounting brackets for the mower in the #3 picture.  I cannot be sure what it is for.
Plow looks GREAT!!!  Yes, you need a new or repaired tire but other than that looks good.  I cannot help with the field cultivator.  Perhaps there are other mouting brackets around.
In any event looks like a good bunch of equipment and considering the age of the mowers - there were brought out around 1950 and stayed till the #7 came out in about 57 - they look in very good shape.
In fact, I have an operting manual for a #3 mower.
Let me know if I may be of assistance.
Good Luck!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2010 at 9:17pm
Thanks guys. Does anyone have a digger like that, its been converted to 3 point, i want to put it back to snap coupler, pictures of the hitch would be very helpful.
Thanks, Carl
HaroldOmaha View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HaroldOmaha Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2010 at 10:28pm
The one #3 mower has a v bracket with bent ends that fit under the WD/WD45 inside the final drives. If you look you will see two stud holes on each side of the interior axel grease cap. There are two brackets that mount here that has a 6" pin that drops into the mount threw the bent ends of the mower mount holding the mower to the tractor.
We had that setup on ower first twin rotor mower. Not the greatest setup. I have some pictures but can't find them now. will try to post later this week.
Jim Lindemood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Lindemood Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2010 at 7:07am
That's quite a haul - ya done good.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2010 at 8:18am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2010 at 8:27am
sorry about the washed out picture. you can see how the mount is installed. Easy to install if you put this part on the tractor back up to it and put the 2 bolts attaching the mower on last. If you try to instaa by lining this up with the mower attached you'll be there awhile.
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2010 at 9:01am
the plow is a model 63 semi-mount. I believe
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2010 at 9:04am
all that nice Orange equipment and he has a green and yellow lawnmower lol
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2010 at 9:10am
I believe Matt is correct on the #63 plow.  I have a #73 that is similar but the #73 could be adjusted from 14" to 16" width.  Your plow has no adjustment holes in the mainframe.
I got a new tire for my plow tailwheel from Miller Tire; about $60 if I recall.  The bigger job is getting the two-piece wheel assembly apart and cleaned back up.  It just takes time and some elbow grease.  Good luck.  Great find.
Brian F(IL)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2010 at 10:00am
Dave, whats the other bracket thats welded to it for, just for looks..lol...where do you find manuals for the sickle mowers, or isnt that manual back in production
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2010 at 3:41pm
The two vertical posts are the U frame that is the pivot point for the #3 Mower.If you look at the 6th picture it's folded back and upside down.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2010 at 4:24pm
oh, ok, that would make sense.. do you know how to mount the other sickle mower. the longer arms i believe go on the lift arms, but what about the lower brackets
Leonard View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leonard Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2010 at 5:39pm
I have one of the #3 mowers but am unable to locate the mounting pins.  Does any one have a source for these?  If so please let me know.
Thanks
Leonard
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2010 at 9:50pm
The other mount in picture 7 the long arms blot to the end of you lift arms. the bottom of the U has one hole. a Bolt through it into your drabar. and the two short arms go foward to the drawbar bail. I don't hav a picture of that mounted it's out in the tree row.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2010 at 4:34pm
im still confused on how it mounts, but ill worry about that later..
What do i need for hydraulic rams for the 2 mowers and the plow.
wkpoor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wkpoor Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2010 at 4:50pm
WOW!!! Is that a nice haul. I would like to get my hands on one of those #3 mowers one day!
