D-17 series 4 wide front question
Josh Day View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh Day Quote  Post ReplyReply Direct Link To This Post Topic: D-17 series 4 wide front question
    Posted: 04 Feb 2017 at 2:12pm
Hello all, I'm going to be rebuilding the wide front on my 17, what's the best way to get the steering arms off of the spindle in order to pull spindle from spindle housing? Thanks! Josh
AC's 75' 7040, 64' D-17S4, 55'WD-45, 54' WD-45, 53' WD-45, 53' WD, 52' CA, 36' WC. IH 656. Deere's 38' A, and 47' A
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2017 at 2:51pm
The arm has to come off the spindle, you can't drive the spindle thru arm and housing. First remove snap ring,arm comes off from top, remove key and spindle should slide out. A little heat will help.HTH
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2017 at 8:59pm
Pull the axel out, turn up side down, slide axel back in. Now you can take a big sledge hammer and beat down on it. Good luck.     MACK
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2017 at 9:51pm
X2.
