125 cu. in. serial #...
Eric B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Topic: 125 cu. in. serial #...
    Posted: 02 Feb 2017 at 1:50pm
Just wondering what details are in the serial # of my 125 cu. in. A-C. The stamped # is CE 87289 G. I figure the G is for gasoline  but CE??  Any info is appreciated - thank you!
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2017 at 2:00pm
CE is just the newer model of engine line that the Bs,Cs, and CAs came out with. Before them was the BE engines. CE engines had a larger bore than the BE engines.
Edited by AJ - 02 Feb 2017 at 2:01pm
Can't fix stupid
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2017 at 2:27pm
and the year of manufacture is approx. 1948.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2017 at 3:02pm
CE = 125 CID.  BE = 116 CID
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric B Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2017 at 4:57pm
Thanks for the enlightenment, as Steve said 1948 ...it is in my '48 B. Because it has distributor ignition I had wondered if the engine was newer than '48. Obviously someone has switched it from mag ignition along the way as that was not available in that year.
This page was generated in 0.083 seconds.
