Wd 45.. worst brake pin stories...
AaronH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronH Quote  Post ReplyReply Direct Link To This Post Topic: Wd 45.. worst brake pin stories...
    Posted: 06 Jun 2010 at 8:29am
Well I managed to pull the shoulders off of the end of the pin... now what??  The pin would move just a bit but very hard. So.. I torched a slot in the pin from the hole in the bottom of the housing and put a pry bar on it.. Little more heat and PB Blaster and I got it to come out far enough to get a vice grips on. its out now.. Whats the worst you have had to do? LOL!!
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2010 at 8:32am
Did you take pictures? Sounds like a good approach as I visualize what you are describing. I expect to be removing the brake pins on my WD45 soon - not sure I want to read TOO many horror stories!!
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2010 at 8:37am
I did what you did but couldn't pry it out, so I hammered the broken end inward until it hit the inside part of the pin, torched off another section, and repeated.  The inside piece on each side came out really easy.
Burgie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2010 at 8:40am
What Chuck did.
"Burgie"
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2010 at 9:16am
Here's my last two storys about removing brake pins. The last brake pins I removed came right out. I removed the two 3/8" bolts and pulled the two pins right out like they had been old yesterday. LOL
Now the set before it was a cutting out in the housing pain in the well you know what!
They can go both ways, Good luck on the other side.
Don
SteveAllisWD50 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveAllisWD50 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2010 at 9:33am
Well I won't go into details of my Nightmare. I used a torch and cut it in the middle. Then drove it in and cut again. I also cut the bottom of the shoes off to get that mess out of my way. Use Antisieze when you reinstall.
Larry(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2010 at 11:07am
my worst was helping a buddy do on his.  We were cutting and pounding away and I had a BFH with a short handle and a punch the almost the size of the pin.  Well, working on a hot night, uncomfortable position and getting pissed by the minute and the "one more hit before I quit" and layed 2 fingers open the was between the housing and the BFH.  Had to set down for a while with hand in ice water feeling woozy.  The  ironic thing is I now own this tractor with the new brakes and brake drums :) with a story to go with it.
'40 WC puller, '65 770 Ollie
*ALLIS EXPRESS contact*
I can explain it to you, BUT I cannot understand it for you!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2010 at 11:33am
Ouch! I feel all the pain.....
WC, CA, D14, WD45
ohnomrbill View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ohnomrbill Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2010 at 4:44pm
Had to take a die grinder to one of mine.  Suffice it to say it took a while ...
Ditto to what SteveAllisWD50 said about anti-seize.
1949 and 1952 WDs
bigfish_Oh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigfish_Oh Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2010 at 5:36pm
I am not to complain about the past ordeal on a 45 or the 45 I have yet to do since it looks like less fun on my D14
1941 WC sat for 29 years,started & dynoed 27 h.p.
1957 WD45 Grandpa bought new,factory p.s.,added wfe
1951 WD, factory p.s.
1960 D14 HnMk IV BkHoe 4 sale
2014 HD Tri Glide
2009 GMC CC SLT Dually
Jason(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jason(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2010 at 7:21pm
Actually, other than taking the final drive and axle off, a D14 isn't that bad. Did mine several years ago, had it done in a 3-4 hours. That included replacing the rear end oil seals too.
However, I have had to torch a set of pins and shoes out of a WD45. Cut tthe bottom of the shoes to get them out, then cut the pin in half and drive inward.
Maurice/Pa. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Maurice/Pa. Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2010 at 7:39pm
    I got my second pin out yesterday, the first one came right out. but the second one .I hit it in as far as i could with a big hammer and still got on it with a vise grip rocking it back and forth with a lot of wd40 sprayed on it. and finely  came out.
Harry up of Mi. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Harry up of Mi. Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2010 at 7:53pm
Machined a puller to hook onto the end of the anchor pin and used two fine thread bolts  to pull with, pin came right out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2010 at 8:55pm
Harry - could you post a picture of that puller? Thanks.
WC, CA, D14, WD45
John In. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John In. Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2010 at 11:44pm
  Not sure which was worse, having to cut and hammer the old pins out or digging into my pocket  book to pay for the new ones..lol...  John
This page was generated in 0.067 seconds.
