cable control for gresen hydraulic valve
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Topic: cable control for gresen hydraulic valve
    Posted: 01 Feb 2017 at 12:27pm
When I get around to putting the cab on our 185, I'm going to need a joystick/cable control kit to operate the loader. Right now it is a one piece, three spool Gresen valve stack, with 3 levers attached to it, and I don't want that mounted in the cab with all of them hydraulic hoses running in and out of the cab. Now I know I can get everything I need new, including a valve stack, but does anyone know if there is a joystick cable kit available that would be compatible with the Gresen valve, so I wouldn't have to buy that new also? Thanks, Darrel
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2017 at 2:24pm
Would think any hydraulic shop should have something.  We had a kit on our 806 with loader, but got it with the loader.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2017 at 7:17pm
Baum Hydraulics http://www.baumhydraulics.com has some joystick kits in my catalog and some control cables too. I didn't detect that the joystick kits could work through cables, seemed only attached directly to valves. I acquired a Long 1099 back hoe years ago with a bad valve that had a joy stick and I converted it to individual levers which I liked better.
Gerald J.
