D 17 Steering Arm Connection
Tyee II View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tyee II Quote  Post ReplyReply Direct Link To This Post Topic: D 17 Steering Arm Connection
    Posted: 30 Jan 2017 at 11:02pm
I pulled a steering arm off of the spindle on one of my D 17s and the woodruff key appears to be the HiPro style 3/8" x 1 1/4". Can anyone tell me if this is correct and if so where can these be purchased ?
RMD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RMD Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2017 at 10:57am
I don't know if that is correct, but you should be able to get most any style/size key from McMaster-Carr: www.mcmaster.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2017 at 11:43am
Any AGCO Dealership can get it for you. I have never seen a Hi-Pro key shear....it always ruins the keyway in the steering arm or spindle or both. You'll probably wind up reassembling it and positioning the arm (arm to tire distance) the same as the other side and welding the arm to the spindle.
