D14/D15 Heads
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Topic: D14/D15 Heads
    Posted: 30 Jan 2017 at 8:19pm
Is there a difference between the head on them like a different casting number or valve size?
Can't fix stupid
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2017 at 10:03pm
I just put a head from a 138 cu. in. engine (early D-10/12) on a D-14 149 cu.in. engine with no problems.  Don't know about the 149 to 160.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2017 at 6:29am
gee Calvin you could have put a D-14 head on that D-14...I got one sitting here ,looking for new home....
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2017 at 1:48pm
138 & 149 heads are interchangeable as mentioned. You can put either of those heads on a 160 if you drill out the head bolt holes. 138 &149 have 7/16" bolts and the 160 has 1/2" bolts. Also the 160 head has a spot to mount the temperature sensor up front in the thermostat pot to get a true temperature reading instead of back over top of the rear exhaust valve where the reading will always be about 20-30 degrees hotter.
