170 Differential carrier seal replacement
Farmer Tom NJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Farmer Tom NJ Quote  Post ReplyReply Direct Link To This Post Topic: 170 Differential carrier seal replacement
    Posted: 30 Jan 2017 at 9:22am
Hi,
I'm in the middle of doing brakes on my '71 170 and was wondering if the oil seal in the differential bearing carrier can be replaced by removing the bolts holding the carrier into the housing, sliding the carrier out, replacing the seal and then reinstalling the carrier?  The manual I have directs you to remove both final drives (I am doing the brakes one side at a time) and the 3pt rockshaft housing to disassemble the diff. Since I am not removing the differential can I take one carrier out at a time to replace the o-ring and oil seal?
Tom J
1955 WD-45, 1971 170 Landhandler, 1948 Farmall Super A, 1965 IH B275 Diesel, 1975 IH 666 Gas, 1969 Case 580CK Backhoe
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2017 at 9:44am
Yes you can replace one seal at a time, I'd replace the O-ring on the bearing carrier too.
nickia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2017 at 9:45am
hello i did my wd 45 and i want to say yes you can just remember to put the seal in right direction and the correct number of shims back under the carrier?  Nick
