B rear axle to wheel spinning
Tom Elder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom Elder Quote  Post ReplyReply Direct Link To This Post Topic: B rear axle to wheel spinning
    Posted: 24 Jan 2017 at 5:50pm
Both my Bs have the  multiple bolts wheel to axle connection ,like the C or CA.On one of my Bs i changed it  out years ago,because it was spinning no matter how much it was tightened.I had a parts tractor with the multiple pattern and switched them out.My question is if there is an easy fix for this,if i run across it again?thanks Tom
2 1949bs,one with belly mower one with side sickle bar
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2017 at 7:21pm
No easy fix. Once the splined stub axle spins in the wheel center one or both of them are toast. You could weld the wheel center to the axle if you NEVER plan to take it off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2017 at 7:26pm
I bought one tractor that way. Shaft was 90% good... Hub was toast. I welded up the inside splines and tried to grind them to size... Was about 60% contact... It ran a couple years, then started to wobble a little... tightened and it ran another year to wobble, etc.. about the third time I bought a good hub and installed on the original axle-- No problems after that.  Hub was about $80. on e-bay.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2017 at 7:28pm
I guess you could take a 3/4 inch thick flange about 8 inches in diameter, and have it welded to the original shaft to make it looks "somewhat" like the 5 bolt style.
