170 power director
tractorhead9542 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorhead9542 Quote  Post ReplyReply Direct Link To This Post Topic: 170 power director
    Posted: 24 Jan 2017 at 6:46am
Hello all. The PowerDirector on my 170 doesn't seem to let go completely. It moves between high and low with ease and does not pop out. However, when placed in neutral and transmission in any gear it's still slowly creeps forward. The foot breaks will hold it back but you can hear the engine drop a little. Does anyone have the procedure for check and adjust on these?
The road to nowhere...leads to me
Lonn View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2017 at 7:02am
It'll do that when the oil is cold. It's normal. I let my tractors warm up at least 15 minutes when it's cold before I drive them. It can be bad for seals to run stone cold.
Wink
I am a Russian Bot
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2017 at 7:16am
My 170 is the same way. It's normal when cold.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorhead9542 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2017 at 7:42am
It doesn't seem to matter whether it's warm or cold. I let my tractor run for a half an hour in temperatures below 30 before operating. At its very best it will hold the tractor like a parking brake on a hill.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2017 at 8:45am
What weight oil are you running?
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorhead9542 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2017 at 8:54am
303 tractor fluid. Oil has 40 hrs on it.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2017 at 9:06am
I think that's normal. My 185 even when warm in the summer, never completely stops without pressing the brake. My WD45 which has a similar hand clutch but without the power director is the same way. That's just the way those wet clutches operate.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorhead9542 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2017 at 9:10am
No I don't think so. Both of my D17's do not act like this. Dave, if you have a wd45 that acts like that you have a serious problem
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2017 at 9:11am
Let's define what "cold" is........Cold is under 120 degrees hyd oil temp. Sounds pretty normal to me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2017 at 9:13am
Just had my hand clutch pulled out of the WD45 a year ago. No problems. I have 80-90 gear oil in the WD45 though which never really thins down.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2017 at 9:29am
It's just the way wet clutches work. There will always be drag on the clutch discs. Thicker oil = more drag. Colder oil = more drag. Now if you can't easily stop it with the brake then you have an issue.
1968 one-seventy
1956 F40 Ferguson
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2017 at 9:34am
My 190 does the same thing until it's warmed up. Sitting running it won't warm up until I'm actually using it. Usually once I've drove it for about 10 minutes and the trany warms up it will stop completely. It warms up much faster using the snow blower. It won't creap if I let the blower down and after a few minutes it won't creap with the blower lifted. Neither of my WD 45s creep at all . Both have the clutch clearance set at .035 and have hytrans in the clutch compartment and 80-90 it the transmition.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2017 at 10:04am
Your D17 clutches are probably a little worn.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorhead9542 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2017 at 10:56am
Ok... I'm reluctant to but I'll take your word for it. Seems out of adjustment. I understand how wet clutch systems work. I've been a heavy machinery mechanic for 17 plus years. Actually for a former AC and FA dealer. Just never had one act like this. Thanks guys
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2017 at 11:01am
If you worried, check it out and make sure all you spacing is correct. I am not a mechanic. I just know how mine works and that nothing is broken inside.
D17JIM2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D17JIM2 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2017 at 11:38am
My 1962 D17 creaps even when warmed up. drop the rear blade to the ground it stops. Both of my brothers series 4's and 170 do too.
Edited by D17JIM2 - 24 Jan 2017 at 11:39am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2017 at 4:40pm
If someone has messed with the shims and didn't do it correctly, that could cause problems. If there is not a grand total of .205" shims at each of 3 locations and identical amounts at each shim pack, the neutral range will be compromised. Like so many posts on here, it's not clear if this tractor is a recent purchase or if this creeping problem has just now surfaced, when it didn't used to bother.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorhead9542 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2017 at 4:45pm
I bought this tractor in April of 2015. It has always been like this and I usually just take the tractor out of transmission gear out of habit now. I'm assuming these shims are the ones inside the cover, not the shims under the lever. It's not really that big of an issue, I just want to make sure that I don't torch the power director.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorhead9542 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2017 at 4:54pm
I don't see any evidence that that side cover has ever been opened up. 3800 hrs original. I'm not trying to sound like a wise***, but I am more than qualified to do a job like this. I am just unfamiliar with the internals of that system and don't want to get into it without a manual or assistance. That being said too, this is my front line tractor and I don't want to damage it or have it down because of negligence or ignorance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2017 at 4:55pm
You can look at the 6 bolt heads on the service cover. If there's one of them that has never had the paint broken, it's never been worked on. Even a repaint job will show if there's been a wrench on bolt heads, unless the bolt head was sand blasted or replaced with new.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2017 at 4:58pm
If you compare dipsticks between an old D-17 and the One-Seventy, I think you'll find the oil level is higher on the newer tractor, which (when oil is cold) causes more creeping.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2017 at 5:58pm
I am no mechanic and have only operated D-series tractors , basically same power director though as a 170 .On our farm growing up none of our D-17's or D-19 creeped with power director in neutral . They were used everyday and I think that keeps the wet clutch discs "polished" . Long after moving off the farm I bought a piece of land and started looking for a D-17 . I looked at a bunch of them for sale and at auctions . Every one of them had what I considered severe creep (have to press brake to keep from moving in neutral position). I was convinced something was wrong with those and wanted no part of them . After finding this site and communicating with people much smarter than me I believe the creeping comes from them sitting and not being used .Someone told me to go out and bale a few thousand haybales with a roto baler and that will cure the creeping . Now if something is out of adjustment it could cause the creep .But from what I have seen posted on here and my own personal experience I would think it just needs played with more .
Also I was taught as a young operator to only use foot clutch for shifting gears and engaging, disengaging PTO .And use power director to make tractor move .Basically put power director in neutral , press foot clutch , change gears , release foot clutch and then engage power director .It was explained to me that the foot clutch would last longer . Now you can leave the power director engaged and only use foot clutch but just relaying what I was taught , probably wrong but I can't get out of the habit now . I have an elderly neighbor a few miles away and he leaves the power director on his D-17 in the low position , never touches it. only uses the foot clutch . I asked him why and he says he never had a hand clutch on the Farmall M he grew up on and wouldn't know how to use it . ????
Edited by Pat the Plumber CIL - 24 Jan 2017 at 5:59pm
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2017 at 5:58pm
The amount of creeping can be reduced but NOT eliminated completely.  Don't need to take anything apart either.  Refer to the picture below - it's not the best picture, but it's the only one I got.
Step 1:  Drive the tractor around quite a while to get the fluid warmed up (best to do it in the summer).
Step 2:  On the inspection cover are 2 nuts on studs.  This holds 2 pieces of metal - the outer one is the high range stop, but you will not do anything with it.  The inner piece extends up towards the seat - this is the one to adjust as it has slotted holes.  Loosen the 2 nuts, but do NOT remove them.
Step 3:  Put the tractor on a level surface, the engine running and the hand clutch in NEUTRAL.
Step 4:  Put the tractor in 1st or reverse (or try both) gear and let your foot off the clutch.  WITHOUT pushing down the button on the hand clutch, gradually move the hand clutch forward or back.  This will move the inner piece on the inspection cover.  You should be able to feel the amount of creep fluctuate.  Keep moving it to where it does not feel as strong.
Step 5.  Hold the hand clutch in this spot and have someone tighten the 2 nuts on the inspection cover.
I have done this to all of my tractors (see my tag line at the bottom of this post).  As mentioned before, creeping is NORMAL especially when things are cold.
Edited by DSeries4 - 24 Jan 2017 at 5:59pm
Big Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Orange Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2017 at 6:18pm
The 303 oil from different companies, are not the same. Use the AGCO 821XL oil. That 303 oil is for JD tractors, not the same viscosity as the AGCO oil.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorhead9542 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2017 at 7:56pm
Dr. Allis- your posts are valid and well-considered. Original paint, boy this tractor is pretty. That's why I suspected an adjustment issue. Actually bought it from from a site member (Rick in MO). I have done a pile of work to this tractor since I bought it to keep it original, yet up-to-date, perfect, and usable. And that is nothing bad to be said about Rick at all. He told me he had it for quite a long time and it's sat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorhead9542 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2017 at 7:59pm
Big orange- our tractor fluid is compatible with A-C fluid. I made sure to get affirmation before I bought a barrel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorhead9542 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2017 at 8:03pm
Hi I tried to read your post but I'm going cross-eyed. It's not what you wrote I'm just tired from the day. I will reread it in the morning. I do appreciate your reply though and thanks a lot.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorhead9542 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2017 at 8:04pm
Sorry, last post was meant for DSeries4...
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorhead9542 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2017 at 8:09pm
To be very clear I have only put approximately 50 hours on this tractor since purchase. Its main purpose is to pull a new idea 3618 spreader and occasionally a Moline disc across a half acre of sand for horse arena and pull wagons up for firewood.
eighty nine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eighty nine Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2017 at 8:12pm
If it's the cheap 303 fluid you get at farm stores for 17 bucks per 5 gal. You're getting just what you paid for, (cheap oil). I would try some good oil as Big Orange sez. Any 303 I have seen is thicker and does not have the additives that the better oils have.
This page was generated in 0.143 seconds.
