b212 with stack/muffler
NATHAN CAIRNS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NATHAN CAIRNS Quote  Post ReplyReply Direct Link To This Post Topic: b212 with stack/muffler
    Posted: 23 Jan 2017 at 8:08pm
i want to put a muffler and a rain cap on my b212  just like this 112 any suggestions on what sized pipe to use or where to buy the muffler
B212, WD45, B, 912 Hydro
macvette View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote macvette Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2017 at 10:03pm
Boy, does that B112 look cool!
truckerfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2017 at 6:30am
I did the same thing to a MTD 960 with a 14hp Briggs. As I recall, it was 3/4" pipe. Seems like the muffler was for an 'A' Farmall. I just went to the tractor muffler section at the local Runnings and went through their selection til I found one with the right inlet to fit the pipe.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NATHAN CAIRNS Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2017 at 8:12pm
oh cool    i dont have a Runnings where i live but i wish i did because farm and home doesnt have a very big exhaust section (illinois)
ac720nut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac720nut Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2017 at 10:22am
Check with Tractor supply store here in Ann Arbor has a selection of mufflers. I think your going to find it to be 1- 1.5 in pipe though  Just my $.02
farmtoybuilder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2017 at 1:27pm
1" pipe threads in block. And you can add a elbow and larger diameter pipe sized to muffler you get.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NATHAN CAIRNS Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2017 at 6:25pm
ok thanks    i have a tsc here where i live   ill check there     i have the briggs engine like the 112 in the picture so i think its the same sized hole     idk for sure
ACmowerguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmowerguy Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2017 at 6:41pm
You need to add some sort of brace to support the extra weight/leverage of that stack. If not it can over time damage the threads in the engine block.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NATHAN CAIRNS Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2017 at 9:25am
ok do you think I can come over from the chrome piece on the front where there is a predrilled hole (probably for headlights) with a piece of steel welded to a hose clamp? and if not where would you mount the support?
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2017 at 1:07pm
Yes that would work. We don't have any on ours, but it doesn't get run much.
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Feb 2017 at 2:18pm
I have been running mine without a brace for years and no problem
Post Options Post Options   Thanks (0) Thanks(0)   Quote NATHAN CAIRNS Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2017 at 7:30pm
ok thanks  ill still probably put a brace on it.  i seen on youtube where a guy made his from galvanized pipe, is that  a good idea? oh and what is the thread size where it goes in the block
Edited by NATHAN CAIRNS - 23 Feb 2017 at 7:32pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2017 at 8:46am
talntedmrgreen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote talntedmrgreen Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2017 at 3:10pm
Most guys run a support over from one or two of the head bolts.  Our TSC has piles of them here.  I'm not a fan and always yank them off tractors I buy and try to get folks to take them when they visit
Patterson B1*B1/B1Forklift*B10*BigTen/B1Loader*B110*B208*B206*616*Homelite T16H/T8/T7/RM7E*Landlord/Loader/Trencher*Broadmoor717*Serf525*2110*7790*Legacy XL*Twin 20*Squire9*Squire6*JCPenny 494
Post Options Post Options   Thanks (0) Thanks(0)   Quote NATHAN CAIRNS Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2017 at 6:29pm
thanks im going to see if i can get pipe sometime this week
