7040 rear rims
johnkc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote johnkc Quote  Post ReplyReply Direct Link To This Post Topic: 7040 rear rims
    Posted: 22 Jan 2017 at 6:06pm
I posted this in the wrong section the other day,so, does any one have a good used set of 8 rail rims for a 7040?  Is welding patches in the rims an acceptable practice or bite the bullet and go new. I am exploring my options any input is appreciated.
these are 18 x 38's
Thanks, John.
I support the development of hybrid automobiles and alternative fuels as I need DIESEL fuel for my ALLIS CHALMERS!
Acfarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acfarm Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2017 at 11:43pm
I have welded and patched a few rims over the years....mostly around the valve stem from all the calcium eating away at the rim.
If you go that route, make sure the patch job is SMOOTH so it does not wear a hole in anything. Also inspect the rim prior to see if it is worth patching.
~Warren
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2017 at 6:00am
Check with salvage yards. Ford and Massey also used those rims. Bought a pair that came from a M-F.
