Help! Bolt stuck in rad
Brampton 02 gt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brampton 02 gt Quote  Post ReplyReply Direct Link To This Post Topic: Help! Bolt stuck in rad
    Posted: 22 Jan 2017 at 4:41pm
The bolt holding the rad to the frame on my Wd spins and won,t come. Is there any thing I can do other than cutting the head off from underneath. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2017 at 5:35pm
Cut it off, and use an insert, in the stripped hole...  Least amount of time, for a small problem...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brampton 02 gt Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2017 at 6:09pm
I wonder if part of the rad broke off and is spinning with the bolt.
DREAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2017 at 8:03pm
Sounds like the insert for the nut has broken the tack weld or the shoulders have rusted off. If you cant get to the nut with vise grips or the like, just cut off the bolt head with a Dremel tool or the like(die grinder). Then get the rest out in similar fashion. Take your time, and it will benefit you in the long run. Nut inserts can be had from McMaster Carr or other industrial suppliers. You can even tack weld, braze, or solder the new one in place, depending on the base material. Just remember to use a little anti-seize when you put the new bolt in, and you wont have a problem next time. Run into this with all kinds of equipment I work on from day to day.
I didn't do it! It was a short, fat, tall, skinny guy that looked like me!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brampton 02 gt Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2017 at 10:50pm
Thanks. That is exactly what happened. I am going to get some needle nose vice grips tomorrow, but I bet I will have to cut it off. The darn dremmel is so slow. I wish I could get the saws all under there.
I need some better air tools I guess. I guess the dremmel beats a hack saw.
tractorboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorboy Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2017 at 1:17am
I don"t know about getting that one out, but i had a @#!% of a time trying to get the holes lined up, & bolt started from underneath this past weekend !!!
corbinstein View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corbinstein Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2017 at 6:18am
would a 4" angle grinder fit?
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2017 at 6:19am
obvious comment but...
when the rads out inspect and repair ALL the others !!!
You'd feel darn silly telling us, "gee guys as I was installing the rad after fixing that one nut, well, guess what?, ANOTHER........."
Jay
ac hunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac hunter Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2017 at 7:38am
Used a cutting torch on one of mine.
Bull View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bull Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2017 at 9:01am
I have a die grinder from H F that is one of the most used tools in my shop. It is real handy for projects like this.
WD45 Diesel, RC,CA,IB, B, G, 616, Early B-10, D-10, Terra Tiger, 95G spreader, SC blade
allisrutledge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2017 at 11:34am
Hack saw and a lot of bandaids! First stick all the bandaids to all the sharp edges and then proceed to saw the bolt. Scott
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2017 at 6:21pm
I agree with you there, I have the 'lectric one, from HF, and its great for little jobs, that are too big for a dremel, but to small, fer a torch...Thumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2017 at 5:00pm
I had one of these that I was able to raise the radiator shell just enough that I could get a sawsall in between the radiator shell and the frame. Depending on how tight this may not be possible. Also nee to be careful that you done damage the shell.
I have had to rebuild a couple of these supports with new steel and new nuts due to rusted sheet metal.
Just and bugger till you get it off!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brampton 02 gt Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2017 at 9:09pm
I can,t believe it but I got it out with needle nose pliers! I went and bought a new set, $34 later, locked them on tight and managed to get the bolt out. Thanks for all of the tips.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2017 at 7:11am
Great news. I love it when a plan come together.
This page was generated in 0.091 seconds.
