d17 puller pieces for sale
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Topic: d17 puller pieces for sale
    Posted: 05 Jun 2010 at 9:15am
I would like to sell as a whole but would break things up. If its broken up the only thing not forsale is the Z code gleanor block . If it sells as a whole the block goes also.  1 box has 4 buda rods with bushings I made to go from 1 inch pin to .927 They are 4 arias flat top 4.125 pistons and 3 c farmall rods in it also. The next box has 4 ross 4 5/8 flt top pistons and four 8 inch billet honda journal  rods . The 4 5/8 pistons have the rings frozen to them they may are may not be useable. The crank is  stroked 6 inches and has the honda rod journal sizes. It could be ground down to the c rod journal and used with the 4.125 arias pistons . The head has comp springs Ferra valves sbc stem size with bronze guides head has been  ported it did have a leak in number 3 exhaust where it was ported though but the belzona has held up that is in that port for 2.5 seasons. the front cam goes in the pict. it was reground at comp cams.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2010 at 9:18am
[IMG]http://i738.photobucket.com/albums/xx26/pankeyc/pics137.jpg[/IMG]
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2010 at 9:35am
flow numbers are available on the head and the original copy will be given at time of purchase.
