D17DIV Rear Tire Size |
Page 12> |
TimNearFortWorth
Topic: D17DIV Rear Tire SizePosted: 22 Jan 2017 at 1:01pm |
Need to get started on an ol' D17DIV I picked up a few years ago. Came with newer MF or Case-IH rear two position rims and junk tires that barely hold air. Found period correct OEM rims/centers that I am having blasted before painting and would like to know what size folks are running for rear rubber.
Have seen some pics from shows where some used some "fatties" front and rear and although it looked tough, this will be a working tractor to earn her keep. Data I have shows 14.9-28's for s/n 42001 and up which is 1962 onwards. All for the tallest I can get on these original rims. Comments/pictures welcome. |
Darb210
Thanks(1)
Posted: 22 Jan 2017 at 1:09pm |
I would go with 16.9x28 if it were mine. Im pretty sure 18.4x28 would fit as well but much harder to find used & much more expensive new.
Dave (NE)
Joined: 12 Sep 2009 Location: Eagle Nebraska Points: 2157 |
Posted: 22 Jan 2017 at 1:20pm |
I've got the 16.9x28 on my series IV's. Have the 18.4x28 on my one-eighty. Wouldn't want to go any smaller than the 16.9's. Dave
Farrell(Utah)
Joined: 11 Sep 2009 Location: Springville, Ut Points: 558 |
Posted: 22 Jan 2017 at 1:40pm |
My 1960 D17 has 16.9X28 tires and I wouldn't want to put smaller ones on it. The 17s look under-tired to me with the 14.9x28 tires. My father bought a new Series 4 D17 that had 18.4X28 tires. Sure made it look like a beast. Your choice will likely depend on your rim width.
A(1937), 2 G, 2 WD45 diesels, 6 WD45 gas, UC, 2 WD, D17 gas, WF, Farmall 400, D12, Kubota B3030
Longmeadow Farm
Joined: 30 Jul 2011 Location: Eastern NY Points: 321 |
Posted: 22 Jan 2017 at 1:43pm |
I would check the rim width of your period correct replacement rims before making your decision. .. actually, you have already made the decision..right?
Eldon (WA)
Joined: 11 Sep 2009 Location: Spokane, WA Points: 7765 |
Posted: 22 Jan 2017 at 1:45pm |
ALLIS EXPRESS!
This year: |
Dans 7080
Posted: 22 Jan 2017 at 1:58pm |
I have 16.9-28s on mine. I wouldn't go any smaller. The 14.9s just don't look right on them.
TimNearFortWorth
Posted: 22 Jan 2017 at 2:42pm |
No Longmeadow I have not, hence the question.
I took the rims from a later SII and the Diesel IV I have is an earlier unit. Running 14.9-28's on a D15II and the extra height makes a world of difference. Was hoping you would post something Eldon as you have likely run every variation possible on the D-Series, thanks for posting the pic. Will be in front of the rims this afternoon and will verify measurement, go from there. |
Eldon (WA)
Posted: 22 Jan 2017 at 2:49pm |
ALLIS EXPRESS!
This year: |
TimNearFortWorth
Posted: 22 Jan 2017 at 4:36pm |
Thanks guys, have 16.9-28's on the IV gasser and thought about bringing the rear height up a tad on the diesel.
Thanks again Eldon as that (before you swapped to the taller front and rear) is exactly what I have front and back on my gasser and I can sure live with that setup. May even mount the A-C loader on her after the engine is addressed. I know, get the check book out, but she is very tired and has serious blow-by . . . . |
Don(MO)
Joined: 12 Sep 2009 Location: Bates City MO. Points: 6862 |
Posted: 22 Jan 2017 at 5:38pm |
Tim, I'd check what just how wide the rims are first, if you have let's say a 14" rim you can get away with running 18.4x28" but if you are going to plow or something that will work the tire hard using a 14" rim I'd run 16.9x28" tires. One more thing to make you think is if you lift the back up with 18.4x28" on the back and are using a loader you might need to go with a taller front too just to keep the tractor level.I like the old tried and true 16.9x28" on the back and 6.50x 16" fronts or if you have six bolt front hubs find a set of 9.5x16" rims and tires to mach-up with the 18.4x28" rears.
Gerald J.
Joined: 12 Sep 2009 Location: Hamilton Co, IA Points: 5636 |
Posted: 22 Jan 2017 at 6:08pm |
Measure your new to you rims especially the width between the bead faces. Then go to an ag tire handbook such as from Titan/Goodyear or other makers and look for the acceptable and preferred rims table and see what tires the manufactures think will fit. A wider tire than the rim will end up wearing mostly the middle of the tread and probably packing the ground more because of the narrower part of the tire taking the load.
Gerald J. |
Dan73
Joined: 04 Jun 2015 Location: United States Points: 6054 |
Posted: 22 Jan 2017 at 6:09pm |
Tim I would consider keeping both the same. It is always nice to be able to swap between the two if something happens sort of like having built in spares. I have a spare tire with industrial tread that fits my d15 and it has saved my butt s couple of times even though I don't like to run it. If it where me I would just try to keep as many common parts as possible. |
Sugarmaker
Joined: 12 Jul 2013 Location: Albion PA Points: 8627 |
Posted: 22 Jan 2017 at 7:17pm |
Tim,
We have a 1958 D17 with the 16.9-28 (Armstrongs) Like others have said, don't go smaller. ![]() Sure wish I could find some Old Firestones like Eldon has on that 17. I think those look to be the original 23 degree type??? Any out there? I would like to try a set for pulling. Regards, Chris |
Dan73
Posted: 22 Jan 2017 at 7:26pm |
2x I like the look of my serries 1 with 16.9 28 as well. Chris there was a posting a little while back someone selling a set of pie weights. They would look great on yours out there at the tractor pulls. |
Sugarmaker
Posted: 22 Jan 2017 at 7:59pm |
Pie weights Would be nice.
Anyone familiar with the Akuret brand tires? Seen a thread on another forum that they were close to the old Firestone 23 degrees?? How about the BKT's?? Regards, Chris |
Allis dave
Joined: 10 May 2012 Location: Northern IN Points: 3086 |
Posted: 23 Jan 2017 at 6:43am |
13" is for 14.9, 15" for 16.9, and 16" for 18.4
You can usually go one tire size either way and still be ok. I agree with everyone else 16.9's are perfect IMO for a D17. I have a 185 with 18.4x28's. and it wouldn't seem quite right to have that tire on a D17. I have 16.9x28's on 15" rims on my WD45. They look pretty mean, but just a hair big. They also set the tractor up just enough that if the plow has settled at all you can't get the tongue into the snap coupler bell. |
victoryallis
Joined: 15 Apr 2010 Location: Ludington mi Points: 2880 |
Posted: 23 Jan 2017 at 7:11am |
Per Agco partsbook it's a 13X28 rim on a D17 enough snow thawed I could get the shed door open at my grandparents and his 17 has the same 4 rail 13X28 rim with a 16.9X28 my 160 does. His 17 has had 16.9X28 for for atleast 40 years and it has been fine.
Gatz in NE
Joined: 11 Sep 2009 Location: Lincoln, NE Points: 1063 |
Posted: 23 Jan 2017 at 9:36am |
16.9 x 28 ... don't go smaller.
These are Titan's "Power Mark" once made by Kelly-Springfield / Goodyear |
Scott B
Joined: 14 Sep 2013 Location: Kansas City Points: 1051 |
Posted: 23 Jan 2017 at 10:06am |
I run 16.9 X 28's as well. Came across a set of firestone 14.9's to have as a replacement. They've been sitting by the barn wall next tot he tractor and every time I look over at them I just think "too small"!
D17 Series 1
Allis B- 1939 Allis B- 1945 |
Dan73
Posted: 23 Jan 2017 at 10:08am |
Now you need to buy a d15 to put those 14.9 s on. Edited by Dan73 - 23 Jan 2017 at 10:08am |
Eldon (WA)
Posted: 23 Jan 2017 at 10:21am |
ALLIS EXPRESS!
This year: |
Eldon (WA)
Posted: 23 Jan 2017 at 10:22am |
ALLIS EXPRESS!
This year: |
dawntreader74
Posted: 23 Jan 2017 at 7:15pm |
16.9X28 are the better way to go. 18.4 are not right because they mess up your ground speed an the tractor don't work ground worth a dam' it's ether to fast or to slow' hard on the tractor
TimNearFortWorth
Posted: 23 Jan 2017 at 8:37pm |
Gatz, if that's the old gal you did up a few years back, I kept every pic you posted as I had not picked up a D17IV as yet and she gave me something to shoot for. Nice, very nice.
Eldon, I'll come out and be your swamper to swap tires around with you, just so I can check out everything in your herd. Get a kick seeing how you rotate some of those gals into service every so often. Wish I had your account for oils and hydraulic fluids as you must buy lubricants by the drum or tote to take care of all of them! If you were located anywhere in the middle of the US, you would never get anything done because of visitors wanting a tour. |
HD6GTOM
Posted: 23 Jan 2017 at 8:52pm |
Tim I bought my series 4 diesel from Allen Reed at R&R equipment in 1980. It had 16.9x28 Uniroyal tires on it. They were the original tires on the tractor. Before I left the tire shop I put 16.9x28 Firestone's on the rear and 750x16 Firestones on the front. That is the way to go.
EPALLIS
Joined: 12 Sep 2009 Location: Illinois Points: 1166 |
Posted: 23 Jan 2017 at 9:44pm |
Yup. 16.9X28 Field and Roads.
Dean/MN
Joined: 14 Sep 2009 Location: Oak Grove, MN Points: 742 |
Posted: 25 Jan 2017 at 4:06pm |
We bought a D17 Series IV new in spring of '68 with 18.4 x 28's on it from the factory. Our 185 was bought new in '72 and it had 18.4 x 30's on it. Both were great for floatation a looked real nice with those tires. I currently have a 185 with 18.4 x 30's on it and I wouldn't want to put 28's on it cause they look weird.
HD16,917H,185,7050,8030FWA,8050FWA
Calvin Schmidt
Joined: 11 Sep 2009 Location: Ontario Can. Points: 4573 |
Posted: 26 Jan 2017 at 5:13am |
I have 14.9 x 38" Firestones on a D-17 IV diesel. They should have come that way!
bradley6874
Joined: 05 Sep 2010 Location: salisbury md Points: 1349 |
Posted: 26 Jan 2017 at 6:49am |
Our series 1 got 18.4 tires when the first set wore out they were b f Goodrich the cracked between the lugs on the sidewall tire dealer blamed rims and if dsd put new rims on the would replace dad put 185 rims it's on 6 th set tires lots of road work wouldn't think about smaller tires never left a mark in any body's hay field with the 18.4
Page 12> |
