620/720 AC 48" rototiller drag plate
macvette View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote macvette Quote  Post ReplyReply Direct Link To This Post Topic: 620/720 AC 48" rototiller drag plate
    Posted: 20 Jan 2017 at 5:06pm
I edited my post to show the size on my tiller, but figured I should post separately as well.
Size is 48 1/2 inches long by 9 inches wide.  A lighter chain is welded near rear center that will reach the little hook on the gearbox to adjust how far down you wish to hang the drag plate.
Merle
ac720nut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac720nut Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2017 at 5:10am
Thanks Merle, mine I guess got bent by po and he never bothered to straighten. I'll get one cut so thanks again
Edited by ac720nut - 21 Jan 2017 at 5:11am
Post Options Post Options   Thanks (0) Thanks(0)   Quote macvette Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2017 at 11:06am
You're welcome.
coggonobrien View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2017 at 3:26pm
anybody got pictures?  Is it flat or formed?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac720nut Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2017 at 5:40pm
 the ones I've seen are flat with a angle on end , I believe to keep from digging in when you back up. At least that will be the way I build mine.
Merle do you have pictures?
Edited by ac720nut - 23 Jan 2017 at 5:41pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote macvette Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2017 at 10:00pm
No pictures, but mine is probably a re-made plate, as the hinges are the regular gate hinges.  It is completely flat, but I don't know how much difference a bend up would make because in my sandy soil, the tiller completely pulverizes the soil, and the plate just drags it smooth.
An upward bend on the rear edge may make a difference in different types of soil.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac720nut Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2017 at 3:57am
The one I looked at had a tube full length and rod for hinge and about a 45* angle on edge
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2017 at 8:45pm
I just saw this post, I will take a picture tomorrow of mine, it's a factory piece.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2017 at 4:20am
Link to 'SimpleTrACtors website.
Rear View of 720 Roto Tiller.
Gary
http://www.simpletractors.net/models/700_series/rotary_tiller.htm
Edited by Gary - 02 Mar 2017 at 4:25am
This page was generated in 0.067 seconds.
