3 Point adapter
TMiller/NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Topic: 3 Point adapter
    Posted: 19 Jan 2017 at 8:18pm
Is there an adapter to convert a 3 point hitch to a pin hitch?  If so does anyone have a picture? Thanks, Tim
ctbowles 58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles 58 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2017 at 8:24pm
you can use the SNAP-COUPLER eye and put a pin through it using a U shaped piece on the pin hitch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2017 at 8:45pm
I don't have any snap coupler or pin hitch equipment,  was thinking of fabricating some type of adapter to attach to disc that would hook up to CA with pin hitch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2017 at 9:13pm
I use something like this... you can put a 2 inch car hitch thru it. I have one end as a ball for the trailer, and the other end flat for pin hitch...... 5/8 inch  lock cross pin in center.
3 Point 2 Receiver Trailer Hitch Category 1 Tractor Tow Hitch Drawbar Adapter
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2017 at 9:18pm
reading your last post, I get the impression you have 3 point equipment and want to attach it to a drawbar pin on the tractor ?   My photo above is to convert a tractor 3 point to a drawbar for dragging equip. ............ but you could do the same, just backward.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2017 at 1:00pm
The disc has a 3 point hitch, I would like to attach to CA with pin hitch and be able to lift it to get to and from point of use and to load on trailer.
rpropst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rpropst Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2017 at 1:52pm
Tim, I have a snap coupler 3 pt adapter. If you want to look at it for ideas or get measurements let me know. 818-291-1757 Richard.   PS I also have part of a homemade pin hitch 3 pt adapter.
Edited by rpropst - 20 Jan 2017 at 2:20pm
1950 snap coupler B 1948 WD 1951Ca 1952B 1952adjustable axel B
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2017 at 2:17pm
I bought a pin hitch to three point adapter from tonys tractors for my CA.Iit works great. I also use it on my snap coupler WD45 i just pull the pin out drop the snap coupler bell and pin it in place. Right now it has a 1000 lb. IH 70 snow blower on it.
This page was generated in 0.081 seconds.
