AC-Mod M Track chain question
1952Dan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1952Dan Quote  Post ReplyReply Direct Link To This Post Topic: AC-Mod M Track chain question
    Posted: 19 Jan 2017 at 11:28am
There are 3 versions of the mod M track chain . The 2nd and 3rd type has a wider rail width in other words the chain bars are 1.25" wide instead of 1" wide on the first type. Does any know of any problems mixing different chains with different year tractors ?
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2017 at 3:47pm
I would think the sprocket and roller width would be the limiting factors.If they fit inside should work. If the pitch of the chain is different that would be more troubling to work with. But from what I understood you to say that is not the case.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2017 at 11:58am
the width or the carrier rollers , idlers and if they run inside or outside on the rails is the limiting factors - the other is pitch of pin spacing and the width of the sprocket to accept the links .
