WC flywheel
ac hunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac hunter Quote  Post ReplyReply Direct Link To This Post Topic: WC flywheel
    Posted: 19 Jan 2017 at 7:06am
I need a little information concerning the flywheel on my 1936 unstyled WC. It is currently a hand crank and has no provision for a ring gear on the existing flywheel. Can anyone tell me if the flywheels on the styled WC and WD will work on my application and accept the existing clutch. Kind of looks that way in the parts manuals but would rather hear it from someone who has been there. Thanks for your help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac hunter Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2017 at 7:13am
Should have explained, I am in the process of converting it to an electric start.
WD45Diesel57 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45Diesel57 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2017 at 7:16am
from my experience with working on the WC,WD and WD45 they are all the same flywheel.
1-B's, 2-C, 2-CA's,2-WF, 1-WC,1-G, 3-WD's, 2-WD45, 1-RC, 1-D17 Diesel, 1-D14, 2-D15,1-D17 row crop,1-D19 gas and All Crop 40,60,66,72,90 and 100
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac hunter Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2017 at 7:17am
Was hoping that was the case. Will make it easier to find one. Thank you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2017 at 4:56pm
Flywheels from WC-WD-WD45 gas engines all interchange. They are not all exactly alike in design, but they interchange and will work in any of the three tractors. Don't be fooled by how they look inside.
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2017 at 3:13pm
Best check clutch sizes.
I know on a B the clutch size is smaller on a flywheel with a ring gear. 8 1/2" vs 9"
Bob
4 B's, 1 C's,3 CA's, 2 G's WD, D14, D15, B-1, B10, B12, 712S,
This page was generated in 0.422 seconds.
