C A Hand Clutch?
Gary(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(MO) Quote  Post ReplyReply Direct Link To This Post Topic: C A Hand Clutch?
    Posted: 18 Jan 2017 at 12:45pm
Guys. I have the final drive off my CA and the hand clutch pack is stuck in it. Any ideas on how to get it out. Does it take a special puller or what? This is first one I have had stuck in housing. TIA Gary
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2017 at 12:47pm
Should just pull right off.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2017 at 10:11pm
Dennis A. I know it should pull out easy but this one is stuck on axle shaft.
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2017 at 10:33pm
Could be rusted on. Might have to provoke it.
I did have one have a stick stuck in between the pack and the housing but didn't put up a very big fight.
Edited by AJ - 18 Jan 2017 at 10:35pm
Can't fix stupid
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2017 at 10:41pm
 Put some penetrating oil on and let sit. Tap on it with a hammer a few times and let sit. Repeat as needed.
Thanks & God Bless
Dennis
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2017 at 9:31am
Patience and persistence is the key. Panther Pi$$ and tapping work on some. Have got some by using long pry bars thru the windows. Have also used a large flat chisel as a "wedge" between the axle shoulder and back of the clutch. Once out clean up the outer axle with Emory Paper and "dress up" the key
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2017 at 11:08am
Thanks guys. I have it soaking and hanging. I have a hook in clutch pack with weight of final drive on it. I tap with center punch(bar) several times a day. Hopeful this will get it loose. Thanks again. Gary
This page was generated in 0.104 seconds.
