AGCO Allis 7600, opinions, questions
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Topic: AGCO Allis 7600, opinions, questions
    Posted: 18 Jan 2017 at 9:26am
I've been snooping around, looking for a cab tractor to replace the 200 for spraying. Tractordata.com says it has a 5 cyl. air cooled diesel, is that correct, 5 cyl.? A syncromesh trans with 4 gears in 3 ranges with a high/low for a total of 24 forward speeds. Is a synchromesh trans shiftable on the fly with the clutch? I'm not a big fan of the air cooled engine but the heaviest work this tractor would ever do is pulling a 700 gallon sprayer around.
Any pros or cons, or opinions are welcome. I don't know if I should go look at one or run from it!
Leon B
tornado8070 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tornado8070 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2017 at 11:38am
Ive drove one and planted for neighbor the year he as laid up. They are buggers to shift, to put it in kind words. If you buy one make sure the brakes work if you need them. Parts are worth their weight in gold.
09’ DT205B, 08’ DT220A, 83' 8070 MFWD, 83’ 8070 85’ 8050 MFWD, 83' 8030, 82' 8010, 85’ 6080 MFWD, 84’ 6080, 79' 7020, 85' M3 RWD, 85' 920 diesel,AC C-50 forklift.
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2017 at 12:24pm
Run!
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2017 at 1:52pm
It is a typical Italian tractor. They are the SAME tractors, right?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2017 at 2:01pm
Yes. Built in Italy.
Looks like I'll keep looking.
Leon B
caledonian View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote caledonian Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2017 at 4:15pm
I'd run from it. Best to keep looking. Or put a cab on your 200.
kinghunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kinghunter Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2017 at 3:52am
I've run a agco allis 7600 for several years now. never once gave me a problem shifting on fly. its my primary baling tractor matter of fact. you can put 100 4x6 bales up on 2/3 tank of fuel. the only complaint I have with tractor is hard to start if below 30 degrees. I have 7000 a 8010 couple 190's several smaller tractors. and I find myself using that agco a lot. if its in Missouri and your not interested pm me where its at I would take another one for pulling disc mower.
Edited by kinghunter - 19 Jan 2017 at 3:54am
